[postgis-users] Slow Postgres Query
dassouki
dassouki at gmail.com
Thu Oct 1 09:30:20 PDT 2009
Emilie Laffray wrote:
> 2009/10/1 dassouki <dassouki at gmail.com <mailto:dassouki at gmail.com>>
> / Hey All,
> />>/ As some of you know, I've been trying to connect a point from
> a point table
> />>/ to the projection of that point on the nearest line for close
> to forever
> />>/ now.
> />>/ I've managed to get the code working for a small set of
> points and lines;
> />>/ however, on a 60 node with 2,000 lines, the query is in its
> 11th hour and
> />>/ still no sign of ending.
> />>/ I posted a question including code on stack overflow
> />>/ http://stackoverflow.com/questions/1504353/slow-postgres-query
> />>/ I was wondering if anyone here has any idea on what I might
> be doing wrong
> />>/ ? and if there is a way to make the code more efficient
> /> Hum, I am no expert but it looks like your 3000000 is way too
> high.
> I tried 1, 100, and 10000 and it didn't seem to speed up the query
> Ok but what is your SRID? You have to pick a meaningful value based on
> your SRID coordinates, with a reasonable amount of slices. It takes a
> bit of trial of error to find the sweet spot for your dataset.
> It depends a lot on the density of points etc...
I'm using SRID 32767 since the input prj file has the following proj:
PROJCS["NAD_1983_CSRS98_New_Brunswick_Stereographic",GEOGCS["GCS_North_American_1983_CSRS98",DATUM["D_North_American_1983_CSRS98",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Double_Stereographic"],PARAMETER["False_Easting",2500000.0],PARAMETER["False_Northing",7500000.0],PARAMETER["Central_Meridian",-66.5],PARAMETER["Scale_Factor",0.999912],PARAMETER["Latitude_Of_Origin",46.5],UNIT["Meter",1.0]]
The area is about 150 sq km, i have roughly 90 nodes, and 2,100 lines
> Emilie Laffray
> postgis-users mailing list
