[postgis-users] Slow Postgres Query
Randall, Eric ERandall at eriecountygov.org
Fri Oct 2 13:23:40 PDT 2009
Thanks Stanly! So to make it a single step I guess...
create table lines_from_points_and_points_projected_onto_centerlines as
select gid as point_id,
(SELECT gid
	from twothousandlines
	order by st_distance(twothousandlines.geom,sixtypoints.geom)
	limit 1
) as line_id,
(SELECT st_makeline(sixtypoints.geom,st_line_interpolate_point(st_geometryn(twothousandlines.geom,1),st_line_locate_point(st_geometryn(twothousandlines.geom,1),sixtypoints.geom)))
	limit 1
) as geom
from sixtypoints
-Eric
Eric Randall
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
Sufficool, Stanley
Sent: Friday, October 02, 2009 3:32 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Slow Postgres Query
I usually avoid cursors when possible:
insert into linespoints (point_id, nearest_line_id)
select gid, (
	SELECT gid
	limit 1
from sixtypoints
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Randall, Eric
> Sent: Friday, October 02, 2009 10:20 AM
> Hi there dassouki,
> Right, no way that should take so long.  I created 60 point
> and 2000 line tables from addresses and road centerlines to
> do a test.  The tables are called "sixtypoints" and
> "twothousandlines".  Then created a "linespoints" table to
> store point and nearest line ids:
> create table linespoints (
> point_id integer,
> nearest_line_id integer );
> Then created a function to insert the point and nearest line ids:
> create or replace function insert_into_linespoints() returns
> integer as $$
> 	declare
>         getrow cursor for select * from sixtypoints;
>         point_row sixtypoints%rowtype;
>         v_nearest_line_id integer;
>         max_rows integer;
> 	  rowcount integer;
> 	begin
> 	  delete from  linespoints;
>         select into max_rows count(*) from sixtypoints;
> 	  open getrow;
>         rowcount := 0;
>         while rowcount < max_rows LOOP   --of course, could
> have just said 60
>         fetch getrow into point_row;
>         rowcount := rowcount + 1;
>         select into v_nearest_line_id
>         twothousandlines.gid
>         order by st_distance(twothousandlines.geom,point_row.geom)
>         limit 1;
>         insert into linespoints values (point_row.gid,
> v_nearest_line_id );
>         end loop;
> 	  close getrow;
> 	  return(rowcount);
>      end;
> $$ language plpgsql
> Then ran it:
> select insert_into_linespoints()   --389ms
> Then made lines from info in the three tables:
> select
> from twothousandlines, sixtypoints, linespoints
> where sixtypoints.gid = linespoints.point_id
> and twothousandlines.gid = linespoints.nearest_line_id
> --12ms
> In retrospect, I probably would add a geometry column to the
> "linespoints" table and insert the line during the function
> rather than having the third step.  I didn't understand why
> you needed to "explode" to linestrings as you called it but I
> guess it has to do with your data.  The "order by
> st_distance() ... limit 1"  is what you needed mainly I think
> to give you each single nearest line.
> Hopefully this is what you're trying to do.
> Eric
> Eric Randall
> Behalf Of dassouki
> Sent: Thursday, October 01, 2009 11:38 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Slow Postgres Query
> Hey All,
> As some of you know, I've been trying to connect a point from a point
> table to the projection of that point on the nearest line for
> close to
> forever now.
> I've managed to get the code working for a small set of points and
> lines; however, on a 60 node with 2,000 lines, the query is
> in its 11th
> hour and still no sign of ending.
> I posted a question including code on stack overflow
> http://stackoverflow.com/questions/1504353/slow-postgres-query
> I was wondering if anyone here has any idea on what I might be doing
> wrong ? and if there is a way to make the code more efficient
> cheers,
> dassouki
> postgis-users mailing list postgis-users at postgis.refractions.net
