[postgis-users] Install postgis on a different schema
Paragon Corporation lr at pcorp.us
Sat Oct 3 15:38:31 PDT 2009
Andrea,
The hardcoding in postgis.sql (I assume you mean the populate...) was a
mistake that we are planning to fix in a (micro or rminor release).  You can
fix it in your copy if you want.  Generally speaking I tend to follow
Stephen's approach because the installing postgis in a non-public schema is
not as tried and tested.
I'm not even sure if there are any assumptions embedded in products that
support postgis we don't know that assume postgis is in public.
Aside from that -- there isn't any problem with that as long as you add the
postgis schema to your database search_path.
Hope that helps,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andrea
Peri
Sent: Saturday, October 03, 2009 12:09 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Install postgis on a different schema
I'm try-ing to install postgis (1.4) on a schema different from 'public'.
There is some documentation on this ?
I notice che postgis.sql has some call on 'public' hardcoded,
so I don't understand if is necessary to install some objects of postgis on
public .
Many thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091003/3901c5d8/attachment.html>
