[postgis-users] PostGIS to calculate time spent within polygon
George Silva
georger.silva at gmail.com
Tue Oct 6 20:19:37 PDT 2009
You can select the interval between minimun and maximum timestamp outside
each polygon. Interpolate to get a value "when entering" the polygon
(intersection between line and polygon) and when leaving.
Then you can subtract both values to get an estimate of time.
You probably can write a simple function for this.
George
On Tue, Oct 6, 2009 at 11:18 PM, Masanao Yajima <yajiyajijp at yahoo.co.jp>wrote:
> Thank you for your response.
> However, would it be possible to elaborate on the 2nd part?
> If my reading of the manual is correct,
> I believe st_intersection is not implemented to handle the 4th dimension.
> Masanao Yajima
> On Tue, Oct 6, 2009 at 6:47 AM, Suhr, Ralf <Ralf.Suhr at itc-halle.de> wrote:
>> Hello Masanao Yajima,
>> for db-design you can go with ogr2ogr (GPX -> PostGIS). Ogr2ogr creates
>> point and line geometrys from gpx files. In case of linestring you have to
>> add the 4. Dimension from the point table.
>> A optimal query would be the intersection from gps-linestrings and your
>> polygon area. The result can be many sublinestrings with start and end time.
>> Gr Ralf
>> *Von:* postgis-users-bounces at postgis.refractions.net [mailto:
>> postgis-users-bounces at postgis.refractions.net] *Im Auftrag von *Masanao
>> Yajima
>> *Gesendet:* Montag, 5. Oktober 2009 23:03
>> *An:* postgis-users at postgis.refractions.net
>> *Betreff:* [postgis-users] PostGIS to calculate time spent within polygon
>> Dear PostGIS users
>> I am new to PostGIS and I would like expert opinion on how to deal with my
>> situation.
>> I have 2D GPS data and time associated with each points and they
>> represents line of a trip.
>> I also have few geographic polygon data representing some area on a map.
>> what I want to get out is length of time that is spent within polygon area
>> for a trip.
>> What is the optimal way to design a database and what kind of query would
>> you use to get such a number.
>> One constraint is the time interval for GPS is not accurate so sampling
>> rate vary alot with in a trip.
>> I thought of using time as 4th dimension but I believe st_intersection is
>> not implemented on the 4th dimension..
>> I could do this by bruit force but I am looking for something fast.
>> I appreciate your help.
>> Masanao Yajima
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Masanao Yajima
George R. C. Silva
Desenvolvimento em GIS
www.sextantegeo2.blogspot.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091007/92842019/attachment.html>
