[postgis-users] Merge lines
Kevin Neufeld
kneufeld at refractions.net
Wed Oct 7 08:40:25 PDT 2009
Correct. It looks like the below query will return coincident lines along contiguous sections of 3 or more (it also
assumes your network is properly directionalized).
This is a problem of transitive closure. I once solved this iteratively by first finding all the degree-2 nodes in my
network, then one node at at time, merging the two lines that share the node.
A modern approach might be to solve this using PostgreSQL's new recursive SQL syntax.
Cheers,
Kevin
Martin Fafard wrote:
> Stanley
> Thank you
> But your query merge two contiguous lines but not 3 or more contiguous
> lines...
> Martin
> Sufficool, Stanley a écrit :
>> Does this look correct?
>> select st_linemerge(st_collect(cs1.the_geom))
>> from (
>> select the_geom, st_startpoint(cs_s.the_geom) as linepoint
>> from mylinetable cs_s
>> UNION ALL
>> select the_geom, st_endpoint(cs_e.the_geom) as linepoint
>> from mylinetable cs_e
>> ) as cs1
>> group by linepoint
>> having count(*) = 2
