[postgis-users] Merge lines
Sufficool, Stanley
ssufficool at sbcounty.gov
Wed Oct 7 12:18:39 PDT 2009
Thanks! I guess having a zero area bounding box would be an illegal
geometry.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Kevin Neufeld
> Sent: Wednesday, October 07, 2009 11:19 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Merge lines
> Sufficool, Stanley wrote:
> > How would the bounding box on a point be a problem with
> group by? I am
> > aware of the classic example of a line 0,0-5,5 and 0,5-5,0 being
> > treated as same when grouped. But does this really apply to points?
> Unfortunately, yes. Consider these two close points that
> have the same bounding box:
> SELECT column1::box2d
> FROM (VALUES
> ('POINT(0.123456789 0.123456789)'::geometry),
> ('POINT(0.123456788 0.123456788)'::geometry)) AS foo;
> column1
> BOX(0.123456783592701 0.123456783592701,0.123456791043282
> 0.123456791043282)
> 0.123456791043282) (2 rows)
> So, using a group by on the bounding box will treat these two
> points will group them together, just like your linear
> example above.
> If your dataset is of significant precision, grouping by the
> hex string of the point works well.
> Cheers,
> Kevin
> postgis-users mailing list postgis-users at postgis.refractions.net
