[postgis-users]  Issue in getting Dijkstra result
    Supunmali Ahangama
    supunmali7 at gmail.com
    Wed Oct  7 18:25:03 PDT 2009
I am doing an application to find the optimal path using Dijkstra function
in pgrouting. I created the topology for the road data. It didnt give any
exception and did work fine when i did it through pgAdmin111 (create source
node, target node for each edge and vertices_tmp).
But when i did run the
            DROP TABLE IF EXISTS dijsktra_result;
CREATE TABLE dijsktra_result(gid int4) with oids;
SELECT AddGeometryColumn('dijsktra_result', 'the_geom', '-1', 'LINESTRING',
2);
INSERT INTO dijsktra_result(the_geom)
            SELECT the_geom FROM dijkstra_sp('edgesnew', 1, 14);
This runs (without any error), but it don't affect any rows. There is
nothing in the created table dijsktra_result.
What should I need to do get the results?
View this message in context: http://www.nabble.com/Issue-in-getting-Dijkstra-result-tp25797106p25797106.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
