[postgis-users] How to Spatialize DB on PostGIS?
Richard Greenwood
richard.greenwood at gmail.com
Fri Oct 9 06:14:58 PDT 2009
Kristi,
It sounds like you are doing everything correctly. If you would like
to send me your data, I would be happy to try loading it on my system
and see if that provides any clues.
Rich
Richard Greenwood
www.greenwoodmap.com
On Wed, Oct 7, 2009 at 8:03 PM, Endah Kristi <kristye_e at yahoo.com> wrote:
> Hi Richard,
> I’ve never attempted to “spatialize” my db before using Easy Loader (because I don’t know how to do that, hehe).
> I don’t have constraints on my table. I’m using PostGIS-pg83-1.3.6-1 and PostgreSQL v8.3.7-1.
> I’ve asked this to PBBI APAC Sydney, and Jesse Hoobler and engineering team told that this problem appeared because I’m not hitting the spatialized database, database has to be spatialized one. They told this is outside of MapInfo domain. So I thought I should do something in PostGIS. I’ll try to ask on the MapInfo-L, I don’t join yet.
> A long time ago, I’ve found the same problem on MapInfo Spatialware, the polygon & polyline can’t be uploaded properly into SQL Server before it’s spatialized. Then I run a script to spatialize that on SQL Server, and I was able to upload them properly. So I thought that PostGIS is the same problem, but if I’m wrong, maybe any advice for me?
> Kristi
