[postgis-users] Closest point on a POLYGON to a given POINT
Juergen Lorenz Simon simon at webtecc.com
Tue Oct 13 02:09:25 PDT 2009
i'm inclined to go with Regina's solution as a starting point (since
it won't involve any looping etc). I'm beginning to see how the
PostGIS 'thinking' works. Could it be that the ST_Buffer() function is
one of the most ... 'used' functions in PostGIS?
Anyways, in the long run I probably have little choice but to write a
real function, since my Poly's do have holes. I will have to take care
of this fact eventually.
Thanks all for the useful answers!
J.
On 13.10.2009, at 02:04, Paragon Corporation wrote:
> Well the ideal solution would be the ST_ShortestLine that Nicklas
> has done
> which will give you a 2 point line where the start and end points
> represent
> the closest point on each geometry.
> This is in
> http://svn.osgeo.org/postgis/spike/nicklas/
> And on the list here
> http://trac.osgeo.org/postgis/ticket/231
> I really would like to see his changes in PostGIS 1.5 since they are
> more
> useful to me at this point than the current slated PostGIS 1.5 stuff
> -- HINT
> HINT
> Barring that I suppose you can do a
> SELECT ST_PointOnSurface(ST_Intersection(ST_Buffer(the_point,
> ST_Distance(the_poly, the_point) + somemarging of error), the_poly)
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Juergen
> Lorenz Simon
> Sent: Monday, October 12, 2009 10:44 AM
> To: PostGIS Users
> Subject: [postgis-users] Closest point on a POLYGON to a given POINT
> Hi,
> I have a nut to crack and i'm not finding anything suitable in the
> PostGIS
> documentation. The problem is as follows:
> I have a POLYGON G and a POINT P. I'd like to find the closest point
> to P on
> G (not in, ON). Is there a quick way of doing this with the build-in
> functions? Or is there some plsql routine I can use?
> Thanks in advance.
> PS: Coming to think of it: is there some open source repository for
> PostGIS
> code?
> postgis-users mailing list
