[postgis-users] Issue with installing PostGIS on CentOS 64 bit
Paragon Corporation
lr at pcorp.us
Fri Oct 16 14:22:28 PDT 2009
Ge,
The problem I was having was definitely a GEOS one. I eventually plan to
move this database to 1.4 or 1.5, but was going to do that after a month or
so. There are way too many stored procs in this particular (most I didn't
write) here that I have to go thru with a fine tooth comb that may need some
rewrite to work with 1.4. Mostly the extent box_extent change in 1.4 has
bitten me on occassion.
For this one I may just jump to 1.5.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of G. van
Es
Sent: Friday, October 16, 2009 5:01 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Issue with installing PostGIS on CentOS 64 bit
I had similar problems. After starting all over with PostGIS 1.4 it runs
fine on CentOS 64Bit (2.6.18-128.7.1.el5 #1 SMP Mon Aug 24 08:21:56 EDT 2009
x86_64 x86_64 x86_64 GNU/Linux)
lwpostgis seems to be renamed to postgis.sql on 1.4 but it runs without
errors.
Ge
--- On Fri, 10/16/09, Paragon Corporation <lr at pcorp.us> wrote:
> From: Paragon Corporation <lr at pcorp.us>
> 64 bit
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net>
> Date: Friday, October 16, 2009, 12:47 AM Forgot to mention version of
> PostgreSQL is
> PostgreSQL 8.4.1
> On Behalf Of Paragon
> Corporation
> Sent: Friday, October 16, 2009 3:44 AM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] Issue with installing PostGIS on CentOS 64
> bit
> We are having an issue installing PostGIS on a CentOS 64-bit box.
> We are doing
> PostGIS 1.3.6
> GEOS 3.1.1
> Proj 4.6.1
> --- the ldd returns the below and running the lwpostgis.sql etc.
> doesn't work since its complaining about the undefined symbols.
> ldd -d /usr/lib64/pgsql/liblwgeom.so
> libgeos_c.so.1 =>
> /usr/lib64/libgeos_c.so.1 (0x00002b40f6a94000)
> libproj.so.0 =>
> /usr/lib64/libproj.so.0 (0x00002b40f6cb5000)
> libc.so.6 =>
> /lib64/libc.so.6 (0x00002b40f6ef6000)
> libgeos-3.1.1.so =>
> /usr/local/lib/libgeos-3.1.1.so
> (0x00002b40f724d000)
> libgcc_s.so.1 =>
> /lib64/libgcc_s.so.1 (0x00002b40f7715000)
> libm.so.6 =>
> /lib64/libm.so.6 (0x00002b40f7923000)
> /lib64/ld-linux-x86-64.so.2
> (0x00002b40f6600000) undefined symbol:
> _ZTVN10__cxxabiv120__si_class_type_infoE
> (/usr/local/lib/libgeos-3.1.1.so)
> undefined symbol: _ZTVN10__cxxabiv117__class_type_infoE
> undefined symbol: __cxa_pure_virtual
> undefined symbol: _ZTISt9exception
> undefined symbol: _ZTVN10__cxxabiv119__pointer_type_infoE
> undefined symbol:
> _ZTVN10__cxxabiv121__vmi_class_type_infoE
> undefined symbol: _ZTVSt9exception
> undefined symbol: _ZSt4cerr
> undefined symbol:
> _ZSt4endlIcSt11char_traitsIcEERSt13basic_ostreamIT_T0_ES6_
> undefined symbol: _ZTIPv
> undefined symbol: __gxx_personality_v0
> undefined symbol: _ZTVN10__cxxabiv120__si_class_type_infoE
> (/usr/lib64/libgeos_c.so.1)
> undefined symbol:
> undefined symbol: SPI_tuptable
> (/usr/lib64/pgsql/liblwgeom.so) undefined
> symbol: CurrentMemoryContext
> symbol: my_exec_path (/usr/lib64/pgsql/liblwgeom.so) undefined
> symbol: textout
> undefined symbol: SPI_processed
> symbol: default_statistics_target
> Thanks,
> Regina
> postgis-users mailing list
