[postgis-users] St_within problem
Michael Smedberg
Michael.Smedberg at redfin.com
Tue Oct 20 09:16:45 PDT 2009
If you use the psql (command line) client, you can use the \o command to
direct output to a text file. That way, you can capture very large text
blocks.
Documentation on psql is available at
http://www.postgresql.org/docs/8.3/static/app-psql.html
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Tuesday, October 20, 2009 9:11 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] St_within problem
Even with astext the geomery is so complex the text can not be
deciphered
as shown in the Output pane.
And pgadmin doesn't have a copy feature (as far as I know).
Bob
----- Original Message -----
From: "Michael Smedberg" <Michael.Smedberg at redfin.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, October 20, 2009 8:29 AM
> You can use the astext function to get the WKT ("well known text".)
> E.g. you could do something like:
> SELECT astext(the_geom) FROM library.dgm_process
> which would return a textual representation of the geometries.
> ST_GeomFromText is the opposite of astext- it'll convert the text to a
> geometry object.
Bob
> Pawley
> Sent: Tuesday, October 20, 2009 8:09 AM
> The geometry comes up true for st_isvalid and yes the points are
> covering
> the geometry and beyond.
> I'm curious as to how I could retrieve the geometry in order to
include
> them
> in an e-mail.
> As a shapefile perhaps??
> Bob
> From: "Maxime van Noppen" <maxime at altribe.org>
> Sent: Monday, October 19, 2009 9:55 AM
>> Bob Pawley wrote:
>>> Funny this does work when I include st_box2d as in -
>>> st_within( graphics.point_grid.the_geom,
>>> st_box2d(library.dgm_process.the_geom))
>>> However, this will include points within the box yet outside of the
>>> actual geometry.
>> It's hard to help without some additionnal data. Did you check that
> your
>> geometry is valid (ST_IsValid) ? Did you manually check that it
> actually
>> contains points ?
>> Maxime
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
