[postgis-users] St_within problem
Maxime van Noppen
maxime at altribe.org
Wed Oct 21 01:36:57 PDT 2009
Michael Smedberg wrote:
> You can use the astext function to get the WKT ("well known text".)
> E.g. you could do something like:
> SELECT astext(the_geom) FROM library.dgm_process
> which would return a textual representation of the geometries.
> ST_GeomFromText is the opposite of astext- it'll convert the text to a
> geometry object.
I suggest the use of the binary WKB format to avoid precision quirks
that might occur with WKT.
SELECT ST_AsBinary(the_geom) FROM ...;
Maxime
