[postgis-users] ST_UNION - Exception in LWGEOM2GEOS
Mehmet Sirin
m.sirin07 at googlemail.com
Tue Oct 27 12:12:45 PDT 2009
indeed there are some linestrings with only 1 Point.
But I don't know how come.. after checking these points I saw that they are
nothing but normal
points on the way ,that means nothing special that should cause a problem.
one of then is on the way 'Ahlde' -> "LINESTRING(7.3402594 52.3361277)"
maybe you should know, that I imported data via osmosis and then created
linestringsby using :
UPDATE ways w SET linestring = (
SELECT MakeLine(c.geom) AS way_line FROM (
SELECT n.geom AS geom FROM nodes n INNER JOIN way_nodes
wn ON n.id = wn.node_id
WHERE (wn.way_id = w.id) ORDER BY wn.sequence_id
) c
2009/10/27 Paragon Corporation <lr at pcorp.us>
> Mehmet,
> It sounds like your line string might have 0 or 1 points.
> Use
> ST_NPoints(linestring) < 2 to find all linestrings with fewer than 2
> points
> Leo
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Mehmet Sirin
> *Sent:* Monday, October 26, 2009 7:24 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] ST_UNION - Exception in LWGEOM2GEOS
> Hi,
> I just tried to create a mutlilinestring out of a set of linestrings via
> SELECT AsText( ST_UNION(linestring) )
> FROM ways w, way_tags wt WHERE w.id=wt.way_id
> AND wt.v='Dörnter Weg'
> (it lies in Osnabrück, lower saxony)
> but I'm getting this strange error:
> HINWEIS: IllegalArgumentException: point array must contain 0 or >1
> elements
> FEHLER: Exception in LWGEOM2GEOS
> ********** Fehler **********
> SQL Status:XX000
> Replacing wt.v='Dörnter Weg' with wt.v='Some other Streets' it works
> properly.
> So it is because of this street 'Dörnter Weg' (i got a few other ones of
> this kind in my database).
> Anybody can tell me why these sort of ways leads to a problem?
> thank you
> kind regards
> mehmet sirin
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091027/4fbd3a0a/attachment.html>
