[postgis-users] How cutting out polygon
Daniel Grum daniel.grum at unibw.de
Tue Sep 1 08:29:54 PDT 2009
Hi.
How I can cut 4 or more differnt polygon geometries out of one big
geomtry[MULTIPOLYGON].
I have one polygon (saved in the schema.tabel.column:
public.fog_of_war.the_geom)
and from this I want to cut out  the squares, that I create with:
SELECT
ST_Intersection(grenze_by.the_geom,ST_Expand(holzfaeller.the_geom, 5000))
FROM public.grenze_by grenze_by, public.holzfaeller holzfaeller
WHERE grenze_by.the_geom && ST_Expand(holzfaeller.the_geom, 5000));
I don't want to save this cut out information in an extra table, I only
want to get a fog_of_war layer.
And You only can see what is behind this Layer(than you see the map and
bulidings) where the layer was cut out.
Can I solve this problem with UPDATE like this:
UPDATE fog_of_war
SET the_geom = (    SELECT
I ask because I get the message: "FEHLER:  als Ausdruck verwendete
Unteranfrage ergab mehr als eine Zeile"
Thanks in advance.
--Daniel
