[postgis-users] Combines polygons within a specified distanceto each other into new polygons.
Paragon Corporation lr at pcorp.us
Sat Sep 5 22:42:24 PDT 2009
Peter,
Try
SELECT a.gid, ST_ConvexHull(ST_Collect(b.the_geom)) As the_geom
INTO polygon_convexhull
 FROM polygon1 As a INNER JOIN polygon1 As b ON
 ST_DWithin(a.the_geom, b.the_geom, 1000)
 GROUP BY a.gid
 HAVING a.gid = MIN(b.gid);
This should create a new table called polygon_convexhull consisting of the
convex hulls.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Peter
Freimuth
Sent: Saturday, September 05, 2009 8:56 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Combines polygons within a specified distanceto
Paragon Corporation schrieb:
> Peter,
> For the harder case where the reference is arbitrary and you are
> trying to calculate many convex hulls.  This will be much slower --
> depending on size of your table. First thought that comes to mind is a
self join.
> The HAVING clause is to try to minimize on a geometry being collected
> in more than one convex hull set.  Its not guaranteed though and also
> depending on your pattern, it may miss some.
> SELECT a.gid, ST_ConvexHull(ST_Collect(the_geom)) As convhull FROM
> table_of_polygons As a INNER JOIN table_of_polygons As b ON
> ST_DWithin(a.the_geom, b.the_geom, some_max_dist) GROUP BY a.gid
> Hope that helps,
> Regina
> Paragon Corporation
> Sent: Saturday, September 05, 2009 11:07 AM
> To: 'PostGIS Users Discussion'
> Peter,
> You would use a combination of ST_DWithin, ST_Collect, and ST_ConvexHull.
> When you say within a max distance -- you mean of a reference geometry
> or from each other?  From each other can be kind of expensive.
> So something of the form
> SELECT ST_ConvexHull(ST_Collect(the_geom))
> FROM table_of_polygons
> WHERE ST_DWithin(ST_GeomFromText(.....), the_geom, max_dist)
> http://postgis.refractions.net/documentation/manual-svn/ST_ConvexHull.
> html
> http://postgis.refractions.net/documentation/manual-svn/ST_Collect.htm
> l
> http://postgis.refractions.net/documentation/manual-svn/ST_GeomFromTex
> t.html
> http://postgis.refractions.net/documentation/manual-svn/ST_DWithin.htm
> l
> Leo
> Peter Freimuth
> Sent: Saturday, September 05, 2009 9:26 AM
> Subject: [postgis-users] Combines polygons within a specified distance
> Hi PostGIS User,
> i am searching for a postgis based solution to create a convexhull on
> groups of polygons which are grouped via a max distance value.
> Any idea or a solution is welcome!
> Kind regards,
> Peter
Thanks Regina for your hint,
find attached the polygons which i try to aggregate and a screenshot of how
it should look like at the end (brown are the results of the aggregation
that i would like to produce and pink are the original polygons).
The solution you proposed  did'nt produce the results that i want. Maybe i
make a mistake.
Anyway, thanks for your help!!
Kind regards,
Peter
Peter Freimuth  Muskauer Str. 11   10997 Berlin
Location:http://www.berlinonline.de/citymap/map.asp?start.x=5&plz=10997&str=
Muskauer+Str.+11&grid=dedatlas10
Tel:+49(0)30-69816610  Mobil:+49(0)175-8434074  Firma:+49(0)3381-8904327
mailto:pfreimuth at arcor.de
skype:pfreimuth
msn:peter_freimuth at hotmail.com
