[postgis-users] Finding that third point on an arc.
Blake Crosby
me at blakecrosby.com
Sun Sep 6 10:59:59 PDT 2009
Problem solved.. It was a transform issue.
Needed to ensure that the curvetoline() function was happening on
geometry that transformed to the proper UTM srid first.
Blake
Blake Crosby wrote:
> Hello,
> I have:
> - Starting Point (lat/long, srid=4326)
> Ps = POINT(-75.7016666666667 45.1127777777778)
> - Ending Point (lat/long, srid=4326)
> Pe = POINT(-75.5627777777778 45.0972222222222)
> - Centre of arc (lat/long, srid=4326)
> Pc= POINT(-75.6333333333333 45.1)
> - Radius (meters: 5556)
> I thought I could construct a circular line string, however you need an
> odd number of points. To get that third point, I was going to use the
> rotate function found here:
> http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctions
> To rotate the starting point (Ps) 90 degrees and use that result as the
> third part of arc.
> The resulting arc looks more like an ellipse when being projected in my
> final projection.
> Does anyone know where I'm going wrong? Essentially I'm doing this:
> Rotate Ps:
> select astext(rotateatpoint(st_geomfromtext('POINT(-75.7016666666667
> 45.1127777777778)',4326),-75.7016666666667,45.1127777777778,pi()/2));
> astext
> generate arc, and convert to a linestring:
> select
> astext(st_curvetoline(st_geomfromtext('CIRCULARSTRING(-75.7016666666667
> 45.1127777777778,-75.5627777777778 45.0972222222222,-75.7016666666667
> 45.1127777777778)',4326)));
> Take a look at the screen shot here. The outer arc is the one generated
> here, the inner one is what I need to get.
> http://www.blakecrosby.com/arc.png
> postgis-users mailing list
