[postgis-users] Points and lines
Suhr, Ralf
Ralf.Suhr at itc-halle.de
Tue Sep 8 00:53:58 PDT 2009
You have a endless loop. You can not have a trigger on update, that do a
update on the same table.
Gr Ralf
Von: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von
Tuomas Ruohonen
Gesendet: Dienstag, 8. September 2009 07:42
An: postgis-users at postgis.refractions.net
Betreff: Re: [postgis-users] Points and lines
What is wrong in my function, it doesnt stop or should it take so
loooong... ? Minutes... Trying to insert to lines in table
CREATE OR REPLACE FUNCTION make_point() RETURNS TRIGGER AS $start_point$
BEGIN
UPDATE positionreports SET the_geom = SetSRID(st_makepoint
("longitude","latitude"), 4326);
RETURN NULL; -- result is ignored since this is an AFTER trigger
END;
$start_point$ LANGUAGE plpgsql;
CREATE TRIGGER start_point
AFTER INSERT OR UPDATE ON positionreports
FOR EACH ROW EXECUTE PROCEDURE make_point();
To: postgis-users at postgis.refractions.net
Date: Mon, 7 Sep 2009 12:59:56 +0300
Subject: [postgis-users] Points and lines
I have this kind of problem that i have 2 tables, another has point data
and another has line data that comes from points. Everything is okay, i
see lines etc.
Now I need trigger or function or ... cause everytime that new point
comes to table i need to update my lines table also that table shows the
latest point in line also.
I hope that you understand what i mean :)
Tell me different kind of options that I have that I can make this
work...
Thanks for everybody !!
-Tuomas
Uusi Spaces ja 25 Gt ilmaista SkyDrive tallennustilaa. Lataa Live
paketti. <http://www.download.live.com/>
Uudessa IE8 selaimessa on uudet pikatoiminnot. Lataa.
<http://www.microsoft.com/finland/windows/products/winfamily/ie/beta/def
ault.mspx>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090908/b9c4dce1/attachment.html>
