[postgis-users] postgis.sql
Mark Vantzelfde
netmasters.ma at gmail.com
Thu Sep 10 02:07:24 PDT 2009
After installing/configuring/making geos, proj4 and postgis from sources on
a new Linux system along with a fresh install of postgresql, I cannot run
the postgis.sql file. I am getting " ERROR: current transaction is aborted,
commands ignored until end of transaction block" errors.
When I ran configure for the postgis build, I had to specify the paths to
geos, proj.4 and postgresql so required libs might not be in the expect
locations. I tried setting LD_LIBRARY_PATH but I am not certain what libs
are needed or where to find them on my system.
Ideas on how to resolve?
Thanks
Mark Vantzelfde
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090910/864b7e1c/attachment.html>
