[postgis-users] postgis.sql
Greg Williamson
gwilliamson39 at yahoo.com
Thu Sep 10 02:35:20 PDT 2009
Mark --
If you cut&paste the first of the errors you get that would be of help (everything after it will be aborted so you could be getting a lot of messages after the relevant one).
Also details on postgres version and full version of postGIS might help.
Your suspicion about not finding the /lib stuff may well be correct. Different Linuxen may behave differently so you might include something about the sort of Linux (Debian, RHL, Ubuntu, what-ever).
Not much help, I'm afraid, but this may be a god starting point.
Greg W.
To: "postgis-users at postgis.refractions.net" <postgis-users at postgis.refractions.net>
Sent: Thursday, September 10, 2009 1:07:24 AM
Subject: [postgis-users] postgis.sql
After installing/configuring/making geos, proj4 and postgis from sources on a new Linux system along with a fresh install of postgresql, I cannot run the postgis.sql file. I am getting " ERROR: current transaction is aborted, commands ignored until end of transaction block" errors.
When I ran configure for the postgis build, I had to specify the paths to geos, proj.4 and postgresql so required libs might not be in the expect locations. I tried setting LD_LIBRARY_PATH but I am not certain what libs are needed or where to find them on my system.
Ideas on how to resolve?
Thanks
Mark Vantzelfde
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090910/6d1f2146/attachment.html>
