[postgis-users] PostGIS 1.4 install troubles
Paul Ramsey
pramsey at cleverelephant.ca
Sat Sep 12 07:53:33 PDT 2009
Run 'locate postgis-1.4.so' and see where the library file actually ended up.
On Sat, Sep 12, 2009 at 7:13 AM, benton101 <Ben.Davies at dec.wa.gov.au> wrote:
> Hi Stephen, This is what the terminal produced ... benton at benton66:~$ sudo su - postgres $ psql -d template_test -f /opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql BEGIN psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:53: NOTICE: type "spheroid" is not yet defined DETAIL: Creating a shell type definition. psql:/opt/PostgreSQL/8.4/share/postgresql/contrib/postgis.sql:53: ERROR: could not access file "$libdir/postgis-1.4": No such file or directory
