[postgis-users] Looking why st_within not working between point3d with box3d
Paul Ramsey
pramsey at cleverelephant.ca
Sat Sep 12 10:08:21 PDT 2009
PostGIS is "2.5D", not 3D, which means that, while Z and M coordinates
are available to store data, they are not used in calculations (with a
few exceptions, for things like linear referencing), they are just
carried along for the ride. Hence what you are observing.
The "box3d" name is confusing and dates back to the 0.X series of
PostGIS, which stored 3 dimensions at all times, even when only two
dimensions existed in the data (in which case the 3rd dimension was
zeroed and hidden in output). The bounding box for such a 3-d
structure would naturally be named, "box3d". But it was never used for
3d calculation, despite the name.
P.
On Sat, Sep 12, 2009 at 9:39 AM, Bruno Friedmann <bruno at ioda-net.ch> wrote:
> Hi All
> I'm facing strange results which I can't explain.
> So any help or idea are welcome.
> Here the context
> Table of point in 3d have been setup.
> SELECT
> st_asewkt(the_geom),
> GeometryType(the_geom),
> NDims(the_geom),
> ZMFlag(the_geom)
> from dom limit 2;
> which seems to return correct 3d point
> "SRID=21781;POINT(602499.98 233307.35 1026.73)";"POINT";3;2
> "SRID=21781;POINT(602499.98 233326.89 1046.81)";"POINT";3;2
> The full extend of data is
> "BOX3D(598125 233000 631.03,602499.98 235999.98 1316.91)"
> Now I try to select rows inside a predefined box
> select id,est,nord,alti_u from dom_1106_42_03
> WHERE st_within(
> the_geom,
> st_setsrid(
> st_makebox3d (
> GeomFromEWKT('SRID=21781;POINT( 598995 233995 500)'),
> GeomFromEWKT('SRID=21781;POINT( 599005 234005 1000)')
> ,21781)
> In this part alti Z is not above 1200 meters so I should not find anything
> but I've got results like this :
> id est nord alti
> 2774523;598995.1600;234002.1500;1209.8700
> 2775215;598995.3800;234001.0900;1210.2600
> 2775297;598995.4000;233999.6300;1207.7600
> It's ok for x,y but not Z
> I don't understand where my problem reside.
> Thanks a lot in advance.
> Bruno Friedmann
> postgis-users mailing list
