[postgis-users] PostGIS upgrade 1.3 to 1.4
Paragon Corporation
lr at pcorp.us
Sun Sep 13 17:42:08 PDT 2009
Yap you can ignore all that. Those are all expected messages.
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Madin
Sent: Sunday, September 13, 2009 6:21 PM
To: PostGIS Users Discussion
Subject: [postgis-users] PostGIS upgrade 1.3 to 1.4
G'day all,
since I'm following the manual, when I tried the soft upgrade, it seemed to
work except for the following Notices:
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:215: NOTICE: type
"box3d_extent" is not yet defined
DETAIL: Creating a shell type definition.
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:219: NOTICE:
argument type box3d_extent is only a shell
CREATE FUNCTION
CREATE AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2683: NOTICE: type
"pgis_abs" is not yet defined
CREATE FUNCTION
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2687: NOTICE:
argument type pgis_abs is only a shell
CREATE FUNCTION
CREATE AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2732: NOTICE:
aggregate accum_old(geometry) does not exist, skipping
DROP AGGREGATE
CREATE AGGREGATE
psql:/usr/local/pgsql/share/contrib/postgis_upgrade.sql:2738: NOTICE:
aggregate st_accum_old(geometry) does not exist, skipping
DROP AGGREGATE
Not being overly knowledgable on PostGIS or PostgreSQL, do these matter?
(I'd almost be confident to guess that the last two messages refer to the
DROP AGGREGATE that follows the message?)
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090913/3b28236a/attachment.html>
