[postgis-users] HARD or SOFT upgrade - documentation questions.
Paragon Corporation lr at pcorp.us
Sun Sep 13 18:00:40 PDT 2009
Ben,
Sorry about that.  The  upgrade section of the docs does need sufficient
revamp.  But been putting it of since we've been working on revamping this
process.
The short answer -- Hard upgrade really doesn't have anything to do with
PostgreSQL version upgrade.  AS long as you have the same version of PostGIS
in your new install as you did in your old install.  Hard upgrade doesn't
come into play.
In the past -- it was kind of iffy when you needed to do a Hard upgrade vs.
a soft upgrade.
Moving forward -- a hard upgrade is only needed if you are moving from major
to major version (e.g. from a 1.3 --> 2.0)
Soft upgrade -- 1.3 ->1.4  , 1.3->1.5 etc.
>From 1.2 its kind of iffy -- you really should do a hard upgrade (or manual
massaging if you know what you are doing) since aggregate functions don't
carry over.
Hope that answers your question,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Madin
Sent: Sunday, September 13, 2009 6:23 PM
To: PostGIS Users Discussion
Subject: [postgis-users] HARD or SOFT upgrade - documentation questions.
And since I'm following the manual, two more questions:
1. Does hard / soft upgrades refer to changes in PostGIS, or changes in
PostgreSQL, or both? Having soft upgraded PostGIS from 1.3.6 to 1.4.0 I
wonder if it is more relevant to the PostgreSQL version number.
2. In the manual, it has the following line :
2.7.2. Hard upgrade
By HARD UPGRADE we intend full dump/reload of postgis-enabled databases. You
need an HARD UPGRADE when postgis objects' internal storage changes or when
SOFT UPGRADE is not possible. The Release
<http://postgis.refractions.net/documentation/manual-1.4/release_notes.html>
Notes appendix reports for each version whether you need a dump/reload (HARD
UPGRADE) to upgrade.
but in the Release Notes appendix I can't find anywhere any guidance on
whether I need a hard or soft upgrade.
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090913/c87ac900/attachment.html>
