[postgis-users] Center of Points Collection
Paul Ramsey
pramsey at cleverelephant.ca
Mon Sep 14 13:13:26 PDT 2009
Very nice approach.
Select ST_MakePoint(avg(ST_X(point_teom)), avg(ST_Y(point_geom))) FROM
pb_statistics WHERE pg_debit =1;
On Mon, Sep 14, 2009 at 1:03 PM, Rick <graham.rick at gmail.com> wrote:
> It occurs to me that, depending on what you want, you might try averaging
> the points to get a median, since you don't have a shape, and thus no
> concept of area to produce a centroid.
> i.e. add them all up and divide by the number of points.
> On Mon, Sep 14, 2009 at 3:28 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
>> Faster than creating a multipoint is to recognize that ST_Centroid()
>> is just going to return the center of the bbox of the collection
>> anyways, so you can replace it with.
>> SELECT ST_Centroid(ST_Extent(point_geom)) FROM pb_statistics WHERE
>> pg_debit =1;
>> If you want to do it the hard way, then:
>> SELECT ST_Centroid(ST_Collect(point_geom)) FROM pb_statistics WHERE
>> pg_debit =1;
>> P.
>> On Mon, Sep 14, 2009 at 12:24 PM, Dustin Butler <dustin at intrcomm.net>
>> wrote:
>> > Hello,
>> > Trying to figure out how to find center using a collection of points.
>> > For
>> > example something like this which doesn't work but you get the idea.
>> > SELECT ST_AsText(ST_Centriod(SELECT point_geom FROM pb.pb_statistics
>> > WHERE
>> > pb_debit=1));
>> > I think I need to make a multipoint geom out of the points and pass that
>> > but
>> > haven't figure out yet.
>> > Thanks,
>> > Dustin Butler
>> > Intrcomm Technology
>> > Skype: dustinbutler
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Cheers!
> Rick
