[postgis-users] No Primary Key
Ravi
ravivundavalli at yahoo.com
Mon Sep 14 15:34:28 PDT 2009
have a problem with a query resulting in a table without a primary key.
Pl suggest a proper SQL
Thanks in anticipation
Ravi
create table coal AS SELECT * from geology where group_='GONDWANA';
From this SQL a table coal is created from table geology with all its columns
as per the argument group_='GONDWANA'
But the resultant table coal is not having a 'primary key'.
table geology has gid as primary key.
Pl give me a way how I can get a primary key on table coal.
Table geology has (copy pasted from pgadmin)
CREATE TABLE public.geology
gid integer NOT NULL DEFAULT nextval('geology_gid_seq'::regclass),
objectid bigint,
group_ character varying(35),
geometry geometry,
CONSTRAINT geology_pkey PRIMARY KEY (gid),
CONSTRAINT enforce_dims_geometry CHECK (ndims(geometry) = 2),
CONSTRAINT enforce_geotype_geometry CHECK (geometrytype(geometry) = 'MULTIPOLYGON'::text OR geometry IS NULL),
CONSTRAINT enforce_srid_geometry CHECK (srid(geometry) = (-1))
WITH (OIDS=FALSE);
ALTER TABLE public.geology OWNER TO postgres;
The query results table coal without primary key (copy pasted from pgadmin)
CREATE TABLE public.coal
gid integer,
objectid bigint,
geometry geometry
WITH (OIDS=FALSE);
ALTER TABLE public.coal OWNER TO postgres;
Looking for local information? Find it on Yahoo! Local http://in.local.yahoo.com/
