[postgis-users] multipoint2point
nicklas.aven at jordogskog.no
Tue Sep 15 01:07:27 PDT 2009
You can use st_dump for that pupose. Then you will get one row per point in your multipoint. select (st_dump(the_multipoint)).geom from thetable /Nicklas
2009-09-15 wrote:
thank you very much ST_MULTI works fine and solves my problem, is there a
>function to cast a MULTIPOINT to POINT?
>----- Original Message -----
>From: "Richard Greenwood"
>To: "PostGIS Users Discussion"
>Sent: Tuesday, September 15, 2009 5:25 AM
>Subject: Re: [postgis-users] multipoint2point
>> You could use st_multi() to cast them al to multi point:
>> ST_Multi(geometry)
>> Returns the geometry as a MULTI* geometry. If the geometry is
>> already a MULTI*, it is returned unchanged.
>> SELECT ST_MULTI(wkb_geometry) FROM table;
>> On Mon, Sep 14, 2009 at 6:22 AM,wrote:
>>> Hi,
>>> I have a postgistable with different geometrytyps in one table: points
>>> and
>>> multipoints (get this information via ST_GeometryType).
>>> UMN Mapserver have no problems to show the geometrys, but if I try to
>>> export
>>> this table via ogr2ogr there is an error:
>>> Attempt to write non-poin(MULTIPOINT) to point shapefile.
>>> How can I cast all my geometrys to point?
>>> Jo
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Richard Greenwood
>> richard.greenwood at gmail.com
>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090915/097326a9/attachment.html>
