[postgis-users] Center of Points Collection - new R book coming out
Paragon Corporation
lr at pcorp.us
Tue Sep 15 17:53:16 PDT 2009
Just thought we would mention since people are talking about it here, that
there is a book coming out on R also by Manning -- due out around the same
time as our book. The two books might make a nice companion set (and I
think their might be some discounts since they are trying to co-sell books
on complimentary topics). Hopefully we'll bit Robert to the punch :)
PostGIS in Action -- http://www.manning.com/obe/
R in Action -- http://www.manning.com/kabacoff/
Leo and Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
pcreso at pcreso.com
Sent: Tuesday, September 15, 2009 3:40 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Center of Points Collection
Hi Chris,
Sorry, I didn't put that well, I meant the centroid of the extent (bbox) is
defined by the outliers, not the centroid of the dataset, in my hierarchy of
arbitrary representativeness :-)
I ain't really a PL/R user, but I'd like to be one. Only 24 hrs in the day,
& I don't know R well enough, I have several workmates who are more than
competent with R, & I work with them for R expertise - much easier & there
are already too many things I don't do well!.
Back on topic, I'd regard a centroid as the ultimate endpoint of a
clustering analysis, & while in PostGIS it does seem to be a simple
averaging approach, there are many more ways to do this. See
http://en.wikipedia.org/wiki/Cluster_analysis
for some examples of how you might otherwise determine a centroid. Or look
up weighted averaging...
Cheers,
Brent
--- On Wed, 9/16/09, Chris Hermansen <chris.hermansen at timberline.ca> wrote:
> From: Chris Hermansen <chris.hermansen at timberline.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Wednesday, September 16, 2009, 7:15 AM Cool, a PL/R user!
> Brent, I'm curious about why you make a distinction between the
> centroid and the average, because as far as I can tell they are the
> same thing.
> wrote:
> > Hi guys,
> > A bit more difficult, & way out in left field, but
> if you use PL/R to create a median function for Postgres, you could
> build your point from the median(X) & (Y) values instead of the
> average.
> > Where this would actually lie obviously depends on the
> distribution of the points. The centroid is most affected by (actually
> defined by) outlying points, the avg somewhat less & the median less
> still.
> > Of course once you have PL/R to play with, you have
> much more flexibility to look at returning statistics from datasets
> than just the median.
> > Cheers,
> > Brent Wood
> > --- On Tue, 9/15/09, Kevin Neufeld <kneufeld at refractions.net>
> wrote:
> >> From: Kevin Neufeld <kneufeld at refractions.net>
> Collection
> >> Date: Tuesday, September 15, 2009, 8:51 AM Paul Ramsey wrote:
> >>> Faster than creating a multipoint is to
> recognize that
> >> ST_Centroid()
> >>> is just going to return the center of the bbox
> of the
> >> collection
> >>> anyways...
> >> Unfortunately, Paul, ST_Centroid returns the
> center of
> >> mass, not the center of the bbox.
> >> SELECT astext(st_centroid(st_collect(column1))),
> >> FROM (values ('POINT(0 0)'),
> ('POINT(0 1)'),
> ('POINT(0 2)'),
> ('POINT(1 0)')) as foo;
> >> astext
> >> POINT(0.25 0.75)
> >> (1 row)
> >> Your second post, taking the avg of the x,y does
> seem to be
> >> the nice approach, and produces the same results
> as
> >> ST_Centroid - the center of mass.
> >> SELECT astext(st_makepoint(avg(st_x(column1)),
> >> avg(st_y(column1))))
> ('POINT(0 1)'),
> ('POINT(0 2)'),
> >> astext
> >> POINT(0.25 0.75)
> >> (1 row)
> >> If Dustin is after the center of the collection,
> then
> >> something along your first suggestion might be
> more
> >> appropriate.
> >> (taking the center of the extents)
> >> Cheers,
> >> Kevin
> >> _______________________________________________
> >> postgis-users mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> -- Regards, (please note new mobile number below)
> Chris Hermansen
> mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 ·
> mob+1.778.840.4625
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
