[postgis-users] Center of Points Collection
Simon Greener
simon at spatialdbadvisor.com
Wed Sep 16 00:16:38 PDT 2009
What would happen if you calculated the median of the x and y ordinates instead of the average?
WITH points As
SELECT st_collect(column1) as the_geom
FROM (values ('POINT(0 0)'),
('POINT(0 1)'),
('POINT(0 2)'),
('POINT(1 0)')) as foo
SELECT astext(st_makepoint(avg(x),avg(y)))
FROM ( SELECT st_x(geom) as x, st_y(geom) as y
FROM (select (ST_Dump(the_geom)).geom as geom from points as foo) as p
ORDER by st_x(geom) ASC, st_y(geom) ASC
LIMIT (select case when mod(ST_NumGeometries(the_geom),2) = 0 then 1 else 2 end from points)
OFFSET (select case when mod(ST_NumGeometries(the_geom),2) = 0 then ST_NumGeometries(the_geom)/2-1 else (ST_NumGeometries(the_geom)-1)/2 end from points)
) T;
-- where p=1 and n=N/2-1 when the number of non null rows N is even, or p=2 and n=(N-1)/2 when N is odd.
"POINT(0 1)"
See http://scorreiait.wordpress.com/2008/10/28/how-to-compute-a-median-in-sql
S
On Wed, 16 Sep 2009 05:25:29 +1000, Chris Hermansen <chris.hermansen at timberline.ca> wrote:
> Hmm on further thought I'm not completely clear on the definition of
> "median" in two dimensions, either. I found this interesting article on
> Google, including a way cool Java app for calculating and graphing:
> http://www.tiac.net/~sw/2007/11/2D_median/index.html
> pcreso at pcreso.com wrote:
>> Hi guys,
>> A bit more difficult, & way out in left field, but if you use PL/R to create a median function for Postgres, you could build your point from the median(X) & (Y) values instead of the average.
>> Where this would actually lie obviously depends on the distribution of the points. The centroid is most affected by (actually defined by) outlying points, the avg somewhat less & the median less still.
>> Of course once you have PL/R to play with, you have much more flexibility to look at returning statistics from datasets than just the median.
>> Cheers,
>> Brent Wood
>> --- On Tue, 9/15/09, Kevin Neufeld <kneufeld at refractions.net> wrote:
>>> From: Kevin Neufeld <kneufeld at refractions.net>
>>> Subject: Re: [postgis-users] Center of Points Collection
>>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>>> Date: Tuesday, September 15, 2009, 8:51 AM
>>> Paul Ramsey wrote:
>>>> Faster than creating a multipoint is to recognize that
>>> ST_Centroid()
>>>> is just going to return the center of the bbox of the
>>> collection
>>>> anyways...
>>> Unfortunately, Paul, ST_Centroid returns the center of
>>> mass, not the center of the bbox.
>>> SELECT astext(st_centroid(st_collect(column1))),
>>> ('POINT(0 1)'),
>>> ('POINT(0 2)'),
>>> ('POINT(1 0)')) as foo;
>>> astext
>>> POINT(0.25 0.75)
>>> (1 row)
>>> Your second post, taking the avg of the x,y does seem to be
>>> the nice approach, and produces the same results as
>>> ST_Centroid - the center of mass.
>>> SELECT astext(st_makepoint(avg(st_x(column1)),
>>> avg(st_y(column1))))
>>> ('POINT(0 1)'),
>>> ('POINT(0 2)'),
>>> astext
>>> POINT(0.25 0.75)
>>> (1 row)
>>> If Dustin is after the center of the collection, then
>>> something along your first suggestion might be more
>>> appropriate.
>>> (taking the center of the extents)
>>> Cheers,
>>> Kevin
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
Email: simon at spatialdbadvisor.com
Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
