[postgis-users] PostGIS 1.4.0 make problems on Solaris 10
Paragon Corporation
lr at pcorp.us
Thu Sep 24 00:02:13 PDT 2009
Andrew,
These settings in 1.4 are picked up from the PostgreSQL PGXS. My guess is
you did not compile your own PostgreSQL 8.4 so maybe those settings are the
defaults for who ever is distributing the binary you have.
This link might help
http://www.postgis.org/pipermail/postgis-users/2009-September/024439.html
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andrew
Smith
Sent: Thursday, September 24, 2009 2:43 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS 1.4.0 make problems on Solaris 10
Hi all,
Let me preface this email by stating that while I have a basic working
knowledge of Solaris, I had never tried compiling an application on that
platform before today. My knowledge of makefiles and the make process is
essentially zero. That being said, here is my problem.
I've been asked to install PostGIS onto a Solaris 10 machine. In order to do
that, I first installed PostgreSQL 8.4.1, then PROJ.4 (4.6.1), then GEOS
(3.1.1). All of those were quite easy and gave me no trouble whatsoever.
Next, I tried to install PostGIS. According to the documentation on the
PostGIS website, this should be as straightfoward as:
./configure
make
make install
Whilst the configure works, the make fails dismally. In a nutshell, here's
the problem:
<snip>
gmake -C postgis
gmake[1]: Entering directory `/tmp/postgis-1.4.0/postgis'
/net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc -Xa -E -traditional-cpp
postgis.sql.in.c | grep -v '^#' > postgis.sql.in
/bin/sh: /net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc: not found
>From what I have been able to understand, there are a couple of .sql.in
files that need to go through the C pre-processor during the make process.
The makefile has this to say:
# Generate any .sql.in files from .sql.in.c files by running them through
the C pre-processor
$(SQL_OBJS): %.in: %.in.c
$(CPP) -traditional-cpp $< | grep -v '^#' > $@
Somehow, $(CPP) is being set to
/net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc, which doesn't exist on my
system. In fact, I haven't been able to find anything about this mysterious
cc process at all. So, my main question is: How does
$(CPP) get set? Is there supposed to be a $CPP environment variable defined
in the shell before I run the gmake command? I'm assuming it's an
environmental problem rather than an issue with the source but have no idea
how to proceed. Any suggestions?
I've included the full output from configure and gmake below.
Cheers,
Andrew
root at server4 # su postgres
root at server4 # gunzip < postgis-1.4.0.tar.gz | tar xpf -
root at server4 # cd postgis-1.4.0
root at server4 # export LD_LIBRARY_PATH=/usr/local/lib
root at server4 #./configure
checking build system type... sparc-sun-solaris2.10 checking host system
type... sparc-sun-solaris2.10 checking for gcc... gcc checking for C
compiler default output file name... a.out checking whether the C compiler
works... yes checking whether we are cross compiling... no checking for
suffix of executables...
checking for suffix of object files... o checking whether we are using the
GNU C compiler... yes checking whether gcc accepts -g... yes checking for
gcc option to accept ISO C89... none needed checking for a sed that does not
truncate output... /usr/bin/sed checking for grep that handles long lines
and -e... /usr/sfw/bin/ggrep checking for egrep... /usr/sfw/bin/ggrep -E
checking for fgrep... /usr/sfw/bin/ggrep -F checking for ld used by gcc...
/usr/ccs/bin/ld checking if the linker (/usr/ccs/bin/ld) is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /usr/ccs/bin/nm -p
checking the name lister (/usr/ccs/bin/nm -p) interface... BSD nm checking
whether ln -s works... yes checking the maximum length of command line
arguments... 786240 checking whether the shell understands some XSI
constructs... yes checking whether the shell understands "+="... no checking
for /usr/ccs/bin/ld option to reload object files... -r checking for
objdump... no checking how to recognize dependent libraries... pass_all
checking for ar... ar checking for strip... strip checking for ranlib...
ranlib checking command to parse /usr/ccs/bin/nm -p output from gcc
object... ok checking how to run the C preprocessor... gcc -E checking for
ANSI C header files... yes checking for sys/types.h... yes checking for
sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes
checking for memory.h... yes checking for strings.h... yes checking for
inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes
checking for dlfcn.h... yes checking for objdir... .libs checking if gcc
supports -fno-rtti -fno-exceptions... no checking for gcc option to produce
PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no checking if gcc supports -c
-o file.o... yes checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/ccs/bin/ld) supports shared
libraries... yes checking whether -lc should be explicitly linked in... yes
checking dynamic linker characteristics... solaris2.10 ld.so checking how to
hardcode library paths into programs... immediate checking whether stripping
libraries is possible... no checking if libtool supports shared libraries...
yes checking whether to build shared libraries... yes checking whether to
build static libraries... yes checking for gcc... (cached) gcc checking
whether we are using the GNU C compiler... (cached) yes checking whether gcc
accepts -g... (cached) yes checking for gcc option to accept ISO C89...
(cached) none needed checking how to run the C preprocessor... gcc -E
checking for g++... g++ checking whether we are using the GNU C++
compiler... yes checking whether g++ accepts -g... yes checking whether we
are using the GNU C++ compiler... (cached) yes checking whether g++ accepts
-g... (cached) yes checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/ccs/bin/ld checking if the linker
(/usr/ccs/bin/ld) is GNU ld... no checking whether the g++ linker
(/usr/ccs/bin/ld) supports shared libraries... yes checking for g++ option
to produce PIC... -fPIC -DPIC checking if g++ PIC flag -fPIC -DPIC works...
yes checking if g++ static flag -static works... no checking if g++ supports
-c -o file.o... yes checking if g++ supports -c -o file.o... (cached) yes
checking whether the g++ linker (/usr/ccs/bin/ld) supports shared
libraries... yes checking dynamic linker characteristics... solaris2.10
ld.so checking how to hardcode library paths into programs... immediate
checking if g++ supports -Wall... yes checking if g++ supports
-Wmissing-prototypes... yes checking for flex... flex checking lex output
file root... lex.yy checking lex library... -lfl checking whether yytext is
a pointer... yes checking for bison... bison -y checking ieeefp.h
usability... yes checking ieeefp.h presence... yes checking for ieeefp.h...
yes checking for convert... /usr/sfw/bin/convert checking for xsltproc...
/usr/bin/xsltproc checking for dblatex... no
configure: WARNING: dblatex is not installed so PDF documentation cannot be
built checking CUnit/CUnit.h usability... no checking CUnit/CUnit.h
presence... no checking for CUnit/CUnit.h... no
configure: WARNING: could not locate CUnit required for liblwgeom unit tests
checking iconv.h usability... yes checking iconv.h presence... yes checking
for iconv.h... yes checking for libiconv_open in -liconv... yes checking for
pg_config... /usr/postgres/8.4-community/bin/pg_config
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes checking for geos-config...
/usr/local/bin/geos-config checking geos_c.h usability... yes checking
geos_c.h presence... yes checking for geos_c.h... yes checking for initGEOS
in -lgeos_c... yes checking proj_api.h usability... yes checking proj_api.h
presence... yes checking for proj_api.h... yes checking for pj_get_release
in -lproj... yes
configure: creating ./config.status
config.status: creating liblwgeom/Makefile
config.status: creating liblwgeom/cunit/Makefile
config.status: creating postgis/Makefile
config.status: creating postgis/sqldefines.h
config.status: creating loader/Makefile
config.status: creating topology/Makefile
config.status: creating regress/Makefile
config.status: creating doc/Makefile
config.status: creating doc/html/image_src/Makefile
config.status: creating postgis_config.h
config.status: executing libtool commands
PostGIS is now configured for sparc-sun-solaris2.10
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.1
PostgreSQL config: /usr/postgres/8.4-community/bin/pg_config
PostgreSQL version: 8.4
PROJ4 version: 46
PostGIS debug level: 0
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
dblatex:
convert: /usr/sfw/bin/convert
root at server4 # gmake
gmake -C liblwgeom
gmake[1]: Entering directory `/tmp/postgis-1.4.0/liblwgeom'
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o measures.o
measures.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
box2d.o box2d.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
ptarray.o ptarray.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c
-o lwgeom_api.o lwgeom_api.c gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -c -o lwgeom.o lwgeom.c gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -c -o lwpoint.o lwpoint.c gcc -g -O2 -fPIC -DPIC
-Wall -Wmissing-prototypes -c -o lwline.o lwline.c gcc -g -O2 -fPIC -DPIC
-Wall -Wmissing-prototypes -c -o lwpoly.o lwpoly.c gcc -g -O2 -fPIC -DPIC
-Wall -Wmissing-prototypes -c -o lwmpoint.o lwmpoint.c gcc -g -O2 -fPIC
-DPIC -Wall -Wmissing-prototypes -c -o lwmline.o lwmline.c gcc -g -O2
-fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmpoly.o lwmpoly.c gcc -g
-O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwcollection.o
lwcollection.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
lwcircstring.o lwcircstring.c gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -c -o lwcompound.o lwcompound.c gcc -g -O2 -fPIC
-DPIC -Wall -Wmissing-prototypes -c -o lwcurvepoly.o lwcurvepoly.c gcc -g
-O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmcurve.o lwmcurve.c
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmsurface.o
lwmsurface.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
lwutil.o lwutil.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
lwalgorithm.o lwalgorithm.c gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -c -o lwgunparse.o lwgunparse.c gcc -g -O2 -fPIC
-DPIC -Wall -Wmissing-prototypes -c -o lwgparse.o lwgparse.c gcc -g -O2
-fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwsegmentize.o lwsegmentize.c
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o wktparse.tab.o
wktparse.tab.c gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
lex.yy.o lex.yy.c
lex.yy.c:4127: warning: 'yyunput' defined but not used gcc -g -O2 -fPIC
-DPIC -Wall -Wmissing-prototypes -c -o vsprintf.o vsprintf.c ar rs
liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o lwutil.o
lwalgorithm.o lwgunparse.o lwgparse.o lwsegmentize.o wktparse.tab.o lex.yy.o
vsprintf.o
ar: creating liblwgeom.a
gmake[1]: Leaving directory `/tmp/postgis-1.4.0/liblwgeom'
gmake -C postgis
gmake[1]: *** [postgis.sql.in] Error 1
gmake[1]: *** Deleting file `postgis.sql.in'
gmake[1]: Leaving directory `/tmp/postgis-1.4.0/postgis'
gmake: *** [postgis] Error 2
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
