[postgis-users] create multipolygon
Maxime van Noppen
maxime at altribe.org
Thu Sep 24 03:18:18 PDT 2009
eehab hamzeh wrote:
> SELECT asEwkt(ST_Multi(ST_Union(ARRAY(SELECT the_geom FROM faces_obj))));
Did you try to simply do :
SELECT ST_Multi(ST_Union(the_geom)) FROM faces_obj;
The ST_Union function will merge polygons if it is possible.
BTW, some of you polygons are invalid (check them with ST_IsValid). For
example the first one :
> # SELECT ST_IsValid('POLYGON((-14161.75 2241.76 2600,-14161.75 2241.76 2900,-14161.75 1941.76 2900,-14161.75 1941.76 2600,-14161.75 2241.76 2600))');
> NOTICE: Too few points in geometry component at or near point -14161.8 2241.76 2600
> st_isvalid
> f
Maxime
