[postgis-users] SQL moving window averages/statistics
Paragon Corporation
lr at pcorp.us
Thu Sep 24 03:35:23 PDT 2009
Kai,
On second thought it appears you are trying to do a 3 day moving average
like thing.
A self-join would probably work best given that the window plumbing in
PostgreSQL doesn't support bounded ranges
SELECT d.date, MAX(d2.tmax) As max_tmax, MIN(d2.tmax) As min_tmax
FROM daily_climate As d INNER JOIN daily_climate As d2
ON( d2.date BETWEEN (d.date - INTERVAL '1 day') AND (d.date + INTERVAL '1
day') )
GROUP BY d.date
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Thursday, September 24, 2009 1:34 AM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] SQL moving window averages/statistics
Kai,
Still not quite sure what you are doing here, but if you are using
PostgreSQL 8.4 you can use the New windowing functions lead(), lag() will
give you forward and backward values. I put in 1 and 1 for example, but if
you wanted to count back say 5 records from your current you would replace
with 5
http://www.postgresql.org/docs/8.4/interactive/functions-window.html
So something like
SELECT date, tmax As curr_tmax, lag(tmax,1) OVER(ORDER BY date) As
previous_day_tmax, lead(tmax,+1) OVER(ORDER BY date) As next_day_tmax FROM
daily_climate;
Leo
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kai
Carter
Sent: Wednesday, September 23, 2009 6:36 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] SQL moving window averages/statistics
Hi there,
I'm currently have an sql statement that selects a week of descriptive
statistics for various historical weather variables, sorted by date.
SELECT to_char(date, 'MM')||to_char(date, 'DD') as date, max(tmax) as
max_tmax, min(tmax) as min_tmax, avg(tmax) as mean_tmax, stddev(tmax) as
std_tmax, count(tmax) as count_tmax, sum(tmax) as sum_tmax, variance
(tmax) as var_tmax FROM daily_climate where icao='KSFO' and (EXTRACT (MONTH
from date) =9 and EXTRACT(DAY from date) = 23) or (EXTRACT (MONTH from
date) = 9 and EXTRACT(DAY from date) = 24) or (EXTRACT (MONTH from date) =
9 and EXTRACT(DAY from date) = 25) or (EXTRACT (MONTH from date) = 9 and
EXTRACT(DAY from date) = 26) or (EXTRACT (MONTH from date) =9 and
EXTRACT(DAY from date) = 27) or (EXTRACT (MONTH from date) = 9 and
EXTRACT(DAY from date) = 28) or (EXTRACT (MONTH from date) = and
EXTRACT(DAY from date) = 29) group by date order by date;
The problem is that I only have 36 years of data to work with, and I would
prefer to have a sample of ~100 rather than 30. So the idea would be to
have a sample statistics for each day made up of 3 days:
the current day, the day previous and the day after.
Is it possible to get this sort of a result with one select statement?
Thanks in advance for your responses,
Kai Carter
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
