[postgis-users] PostGIS 1.4.0 make problems on Solaris 10
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 24 08:18:00 PDT 2009
Could be in your environment (I really don't know how you're getting
that *particular* cpp and it's even odder that it's not actually
there, echo $CPP and see). If you override the CPP environment
variable with one you know *is* cpp and is available you should be OK.
P.
On Wed, Sep 23, 2009 at 11:43 PM, Andrew Smith <laconical at gmail.com> wrote:
> Hi all,
> Let me preface this email by stating that while I have a basic working
> knowledge of Solaris, I had never tried compiling an application on
> that platform before today. My knowledge of makefiles and the make
> process is essentially zero. That being said, here is my problem.
> I've been asked to install PostGIS onto a Solaris 10 machine. In order
> to do that, I first installed PostgreSQL 8.4.1, then PROJ.4 (4.6.1),
> then GEOS (3.1.1). All of those were quite easy and gave me no trouble
> whatsoever.
> Next, I tried to install PostGIS. According to the documentation on
> the PostGIS website, this should be as straightfoward as:
> ./configure
> make
> make install
> Whilst the configure works, the make fails dismally. In a nutshell,
> here's the problem:
> <snip>
> gmake -C postgis
> gmake[1]: Entering directory `/tmp/postgis-1.4.0/postgis'
> /net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc -Xa -E
> -traditional-cpp postgis.sql.in.c | grep -v '^#' > postgis.sql.in
> /bin/sh: /net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc: not found
> From what I have been able to understand, there are a couple of
> .sql.in files that need to go through the C pre-processor during the
> make process. The makefile has this to say:
> # Generate any .sql.in files from .sql.in.c files by running them
> $(SQL_OBJS): %.in: %.in.c
> $(CPP) -traditional-cpp $< | grep -v '^#' > $@
> Somehow, $(CPP) is being set to
> /net/grok/ontools/onnv-tools/SUNWspro/SS11/bin/cc, which doesn't exist
> on my system. In fact, I haven't been able to find anything about
> this mysterious cc process at all. So, my main question is: How does
> $(CPP) get set? Is there supposed to be a $CPP environment variable
> defined in the shell before I run the gmake command? I'm assuming
> it's an environmental problem rather than an issue with the source but
> have no idea how to proceed. Any suggestions?
> I've included the full output from configure and gmake below.
> Cheers,
> Andrew
> root at server4 # su postgres
> root at server4 # gunzip < postgis-1.4.0.tar.gz | tar xpf -
> root at server4 # cd postgis-1.4.0
> root at server4 # export LD_LIBRARY_PATH=/usr/local/lib
> root at server4 #./configure
> checking build system type... sparc-sun-solaris2.10
> checking host system type... sparc-sun-solaris2.10
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for a sed that does not truncate output... /usr/bin/sed
> checking for grep that handles long lines and -e... /usr/sfw/bin/ggrep
> checking for egrep... /usr/sfw/bin/ggrep -E
> checking for fgrep... /usr/sfw/bin/ggrep -F
> checking for ld used by gcc... /usr/ccs/bin/ld
> checking if the linker (/usr/ccs/bin/ld) is GNU ld... no
> checking for BSD- or MS-compatible name lister (nm)... /usr/ccs/bin/nm -p
> checking the name lister (/usr/ccs/bin/nm -p) interface... BSD nm
> checking whether ln -s works... yes
> checking the maximum length of command line arguments... 786240
> checking whether the shell understands some XSI constructs... yes
> checking whether the shell understands "+="... no
> checking for /usr/ccs/bin/ld option to reload object files... -r
> checking for objdump... no
> checking how to recognize dependent libraries... pass_all
> checking for ar... ar
> checking for strip... strip
> checking for ranlib... ranlib
> checking command to parse /usr/ccs/bin/nm -p output from gcc object... ok
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking for dlfcn.h... yes
> checking for objdir... .libs
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC -DPIC
> checking if gcc PIC flag -fPIC -DPIC works... yes
> checking if gcc static flag -static works... no
> checking if gcc supports -c -o file.o... yes
> checking if gcc supports -c -o file.o... (cached) yes
> checking whether the gcc linker (/usr/ccs/bin/ld) supports shared
> libraries... yes
> checking whether -lc should be explicitly linked in... yes
> checking dynamic linker characteristics... solaris2.10 ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... no
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> checking for gcc... (cached) gcc
> checking whether we are using the GNU C compiler... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for gcc option to accept ISO C89... (cached) none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking whether we are using the GNU C++ compiler... (cached) yes
> checking whether g++ accepts -g... (cached) yes
> checking how to run the C++ preprocessor... g++ -E
> checking for ld used by g++... /usr/ccs/bin/ld
> checking whether the g++ linker (/usr/ccs/bin/ld) supports shared
> libraries... yes
> checking for g++ option to produce PIC... -fPIC -DPIC
> checking if g++ PIC flag -fPIC -DPIC works... yes
> checking if g++ static flag -static works... no
> checking if g++ supports -c -o file.o... yes
> checking if g++ supports -c -o file.o... (cached) yes
> libraries... yes
> checking if g++ supports -Wall... yes
> checking if g++ supports -Wmissing-prototypes... yes
> checking for flex... flex
> checking lex output file root... lex.yy
> checking lex library... -lfl
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking ieeefp.h usability... yes
> checking ieeefp.h presence... yes
> checking for ieeefp.h... yes
> checking for convert... /usr/sfw/bin/convert
> checking for xsltproc... /usr/bin/xsltproc
> checking for dblatex... no
> configure: WARNING: dblatex is not installed so PDF documentation
> cannot be built
> checking CUnit/CUnit.h usability... no
> checking CUnit/CUnit.h presence... no
> checking for CUnit/CUnit.h... no
> configure: WARNING: could not locate CUnit required for liblwgeom unit tests
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking for libiconv_open in -liconv... yes
> checking for pg_config... /usr/postgres/8.4-community/bin/pg_config
> checking libpq-fe.h usability... yes
> checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes
> checking for PQserverVersion in -lpq... yes
> checking for geos-config... /usr/local/bin/geos-config
> checking geos_c.h usability... yes
> checking geos_c.h presence... yes
> checking for geos_c.h... yes
> checking for initGEOS in -lgeos_c... yes
> checking proj_api.h usability... yes
> checking proj_api.h presence... yes
> checking for proj_api.h... yes
> checking for pj_get_release in -lproj... yes
> configure: creating ./config.status
> config.status: creating liblwgeom/Makefile
> config.status: creating liblwgeom/cunit/Makefile
> config.status: creating postgis/Makefile
> config.status: creating postgis/sqldefines.h
> config.status: creating loader/Makefile
> config.status: creating topology/Makefile
> config.status: creating regress/Makefile
> config.status: creating doc/Makefile
> config.status: creating doc/html/image_src/Makefile
> config.status: creating postgis_config.h
> config.status: executing libtool commands
> PostGIS is now configured for sparc-sun-solaris2.10
> -------------- Compiler Info -------------
> C compiler: gcc -g -O2
> C++ compiler: g++ -g -O2
> -------------- Dependencies --------------
> GEOS config: /usr/local/bin/geos-config
> GEOS version: 3.1
> PostgreSQL config: /usr/postgres/8.4-community/bin/pg_config
> PostgreSQL version: 8.4
> PROJ4 version: 46
> PostGIS debug level: 0
> -------- Documentation Generation --------
> xsltproc: /usr/bin/xsltproc
> xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
> dblatex:
> convert: /usr/sfw/bin/convert
> root at server4 # gmake
> gmake -C liblwgeom
> gmake[1]: Entering directory `/tmp/postgis-1.4.0/liblwgeom'
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o measures.o measures.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o box2d.o box2d.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o ptarray.o ptarray.c
> lwgeom_api.o lwgeom_api.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwgeom.o lwgeom.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwpoint.o lwpoint.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwline.o lwline.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwpoly.o lwpoly.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmpoint.o lwmpoint.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmline.o lwmline.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmpoly.o lwmpoly.c
> lwcollection.o lwcollection.c
> lwcircstring.o lwcircstring.c
> lwcompound.o lwcompound.c
> lwcurvepoly.o lwcurvepoly.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwmcurve.o lwmcurve.c
> lwmsurface.o lwmsurface.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwutil.o lwutil.c
> lwalgorithm.o lwalgorithm.c
> lwgunparse.o lwgunparse.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lwgparse.o lwgparse.c
> lwsegmentize.o lwsegmentize.c
> wktparse.tab.o wktparse.tab.c
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o lex.yy.o lex.yy.c
> lex.yy.c:4127: warning: 'yyunput' defined but not used
> gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o vsprintf.o vsprintf.c
> ar rs liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
> lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o
> lwcollection.o lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o
> lwmsurface.o lwutil.o lwalgorithm.o lwgunparse.o lwgparse.o
> lwsegmentize.o wktparse.tab.o lex.yy.o vsprintf.o
> ar: creating liblwgeom.a
> gmake[1]: Leaving directory `/tmp/postgis-1.4.0/liblwgeom'
> gmake -C postgis
> gmake[1]: *** [postgis.sql.in] Error 1
> gmake[1]: *** Deleting file `postgis.sql.in'
> gmake[1]: Leaving directory `/tmp/postgis-1.4.0/postgis'
> gmake: *** [postgis] Error 2
> postgis-users mailing list
