[postgis-users] Merging two overlapping polygons
Alexandre Dube adube at mapgears.com
Wed Sep 30 07:40:46 PDT 2009
Emilie,
Emilie Laffray wrote:
> Performing an intersect check would work I guess if you revamped your
> query accordingly.
Thanks for the help.
OK, using ST_Intersects should be fine when using only 2 geometries, but
how can I use this in a query on a table containing more than 15000 rows ?
ST_Union worked and returned a single multipolygon, that's a good
start.  Is it possible to merge "intersecting" polygons only in a
statement ?
So far :
SELECT mycolumn, ST_Multi(ST_Union(f.the_geom)) as singlegeom FROM
mytable As f GROUP BY mycolumn;
(btw, mycolumn has the same value for every row, i.e. is null)
Thanks a lot,
> Emilie Laffray
> postgis-users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
