[postgis-users] linestring clipping problem
Brian Modra brian at zwartberg.com
Wed Sep 30 12:37:34 PDT 2009
Create a new clip polygon which is the differenec between the blue one and
the outer rectangle. then aply that one as you did the blue one.
2009/9/30 James G Wilkinson <jgw at alpinegeophysics.com>
>  Folks,
> I am having a problem determining the best way to clip out and disgrad a
> set of linestrings.  Here is my setup:
> itn=# select postgis_full_version();
>  POSTGIS="1.3.2" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS (procs from 1.1.2 need upgrade)
> (1 row)
> itn=# select version();
> version
>  PostgreSQL 8.1.3 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
> 4.0.0 20050519 (Red Hat 4.0.0-8)
> (1 row)
> My linestring network has the following attributes (and a picture for
> visualization):
> itn=# \d itn.scaglinks
>                                                   Table "itn.links"
>          Column         |       Type
> Modifiers
>  record_id_alternate    | integer          | not null default
> nextval('itn.scaglinks_record_id_alternate_seq3'::regclass)
>  a_node                 | integer          |
>  b_node                 | integer          |
>  dist                   | integer          |
>  taz_id                 | integer          |
>  .<clip>
>  .<clip>
>  the_geom               | geometry         |
> Indexes:
>     "idx_scaglinks_00" btree (a_node)
>     "idx_scaglinks_01" btree (b_node)
>     "idx_scaglinks_02" btree (a_node, b_node)
>     "idx_scaglinks_03" btree (link_id)
>     "pkgis_scaglinks" gist (the_geom)
> Check constraints:
>     "enforce_dims_the_geom" CHECK (ndims(the_geom) = 2)
>     "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'MULTILINESTRING'::text OR the_geom IS NULL)
>     "enforce_srid_the_geom" CHECK (srid(the_geom) = 26911)
> [image: scaglinks.GIF]
> My clipping polygon has the following attributes (and a picture for
> visualization):
> itn=# \d itn.itn_clip_polygon_1
>  Table "itn.itn_clip_polygon_1"
>   Column  |   Type   | Modifiers
>  cyid     | integer  |
> Indexes:
>     "pkgis_itn_clip_polygon_1" gist (the_geom)
> [image: scaglinks_clip_polygon.GIF]
> When I run the following command to clip the scaglinks linestrings, the
> results are what I would expect (again, a picture for visualization):
> itn=# create table clipped as select intersection(a.the_geom,b.the_geom) as
> new_geom, length(a.the_geom) as original_link_length, a.* from scaglinks a,
> itn_clip_polygon_1 b where intersects(a.the_geom,b.the_geom);
> SELECT
> itn=# create index pkgis_clipped on clipped using gist(new_geom);
> CREATE INDEX
> itn=# \d itn.clipped
>                   Table "itn.clipped"
>  new_geom               | geometry         |
>  original_link_length   | double precision |
>  a_node                 | integer          |
>  b_node                 | integer          |
>  dist                   | integer          |
>  taz_id                 | integer          |
>  .<clip>
>  .<clip>
> Indexes:
>     "pkgis_clipped" gist (new_geom)
> [image: scaglinks_clipped.GIF]
> What I am really after are the links that fall outside the clipping
> polygon.  So I attempted the following query:
> itn=# create table clipped2 as SELECT a.*,
> difference(a.the_geom,b.new_geom) as new_geom from scaglinks a, clipped b;
> ******** after 12 hours, the query throws the following error ********
> ERROR: could not extend relation 1663/164540/180960: No space left on
> device
> HINT: Check free disk space
> The scaglinks network consists of 108,000 links and the clipped network
> consists of 6,200 links.  I have approximately 1.5 TB of free disk so I
> do not believe that disk space should be a problem.
> Again, what I had hoped is that the query to create clipped2 would return
> a table that results in the following graphic:
> [image: but_want_this.GIF]
> Can you offer any help in the query that will result in a table that
> looks something like the last graphic?
> Best Regards,
> Jim
> postgis-users mailing list
Brian Modra   Land line: +27 23 5411 462
Mobile: +27 79 69 77 082
5 Jan Louw Str, Prince Albert, 6930
Postal: P.O. Box 2, Prince Albert 6930
South Africa
http://www.zwartberg.com/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/774e8f32/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/774e8f32/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/774e8f32/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/774e8f32/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090930/774e8f32/attachment-0003.png>
