[postgis-users] Address Geocoding
ibrahim saricicek
ibrahimsaricicek at gmail.com
Thu Apr 1 05:27:50 PDT 2010
Hi all,
I mean one of those, not one table at a time.
Or creating a function;
SELECT id, the_geom
FROM roads
WHERE
the_geom && SetSRID('BOX3D(x+0.01 y+0.01, x-0.01 y-0.01)'::box3d, 4326)
ORDER BY
ST_Distance(the_geom, GeomFromText('POINT(x y)', 4326))
LIMIT 1;
if this is null try the others; settlements, poi, province, etc...
Regards...
On Tue, Mar 30, 2010 at 4:49 AM, Oscar Zamudio <cmntlk at gmail.com> wrote:
> When you write: "FROM (roads, settlements, poi, province, etc...)" you
> actually mean one table at a time? Because if you try more than one table
> separated by commas, there will be an error. If you are trying to use more
> than one table I'm afraid you will need to use a JOIN clause ...
> Regards,
> On Wed, Mar 24, 2010 at 6:21 AM, ibrahim saricicek <
> ibrahimsaricicek at gmail.com> wrote:
>> Hi;
>> for reverse geoceding now using this and works fine;
>> SELECT id, the_geom
>> WHERE
>> ORDER BY
>> LIMIT 1;
>> regards...
>> On Fri, Mar 19, 2010 at 8:23 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> http://www.google.com/#hl=en&source=hp&q=postgis+geocoder
>>> Ricardo Bayley wrote:
>>>> Hi fellows,
>>>> I was wondering if any of you have a good approach to do Address
>>>> Geocoding within postgis.
>>>> Any ideas, considerations, thoughts ??
>>>> thanks in advanced.
>>>> Warm regards,
>>>> Ricardo
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100401/9ddbef1c/attachment.html>
