[postgis-users] Problem building Postgis 1.5.x for Pg 8.4 on Ubuntu 9.10
Zubair Assad
i.am.zubu at gmail.com
Fri Apr 2 03:22:43 PDT 2010
I am having trouble building postgis 1.5.x for Pg 8.4
Here are things installed:
$ sudo apt-get install postgresql-server-dev-8.4 libpq5 libpq-dev
Here is a past to my config.out: http://pastebin.com/8Nk6pr96
And, here are some hints I got from IRC (names concealed)
< foo> it's NOT failing to find libpq.
< foo> libpq is present, but not compilable without adding a boatload
of other -l flags
< foo> and postgis' configure doesn't let you specify that via LIBS
< foo> the paste contains the config.out, which shows this
The configure dies with this, configure: error: could not find libpq
I intend to install postgis for mapfish :)
http://stackoverflow.com/questions/2563434/problem-building-postgis-1-5-x-for-pg-8-4-on-ubuntu-9-10
Thanks and Regards
Zubair Assad
