[postgis-users] steps in creating a new database
Edward Mac Gillavry
emacgillavry at hotmail.com
Fri Apr 9 03:42:49 PDT 2010
Cristian,
In PostGres, you can set up a new database scheme using a particular template. For spatial databases, you can create a template, so you don't have to add the postgis extensions or spatial reference systems each time you create a new spatial database. So you first create a new template for spatial databases that we call "template_postgis".
createdb template_postgis
$ createlang plpgsql template_postgis (plpgsql provides the functionality to use the spatial extensions)
$ psql -d template_postgis -f postgis/postgis.sql
$ psql -d template_postgis -f spatial_ref_sys.sql (contains the parameters of the various spatial reference systems, describing the projections and coordinate systems)
Next you grant the appropriate actions to the user "postgres".
# grant select, update, insert, delete on table geometry_columns to postgres;
# grant select on table spatial_ref_sys to postgres;
#\q
Since you do not want each database to be owned by postgres (just as you wouldn't want every directory in your file system to be owned by root), let's create a new user "gisuser":
$ createuser gisuser -P
Finally, you create your spatial database "gisdb" that is owned by the new user "gisuser". For this, you simply use the template that you created earlier "template_postgis". So, you create your template once and re-use every time you create a new spatial database, gisdb1, gisdb2, gisdb3 or a more explanatory database name.
$ createdb -T template_postgis -E UTF8 -O gisuser gisdb
Hope this helps.
Edward
Date: Fri, 9 Apr 2010 12:10:47 +0200
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] steps in creating a new database
Hi all,
I try to create a new postgis database on Ubuntu, and I'm quite confused about the steps in creating a database.
Creating database:
# createdb -T [template] [name_of_the_database]
- what are the use [-T] and [template] in this line
- I can create my own template? for example: # createdb -T [general_data] [world]
Adding plpsql language to the database:
# createlang plpgsql [database]
# psql -d [database] -f
/usr/share/postgresql/8.4/contrib/postgis.sql
/usr/share/postgresql/8.4/contrib/spatial_ref_sys.sql
# psql -d [database] -c"select
postgis_lib_version();"
- is plpgsql a condition in creating a geodatabase
- what's happening if I don't add this line # psql -d [database] -f
- This are the complete steps in creating a spatial database?
- Where i can find more information regarding this subject?
Thank you,
Cristian
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100409/0012982b/attachment.html>
