[postgis-users] how to backup/restore
Robin Chauhan
robin.chauhan at gmail.com
Sun Apr 11 18:52:46 PDT 2010
I have a database I've been maintaining for a few years, in which postgis is
in the public schema.
Is there any sane way for me to strip out the public-schema postgis
elements?
I have been upgrading postgis on this database from postgres 7.4 days, and
it works well though its crufty. I would love to have it installed over a
fresh, clean postgis.
Thanks,
=Robin
On Sun, Apr 11, 2010 at 6:47 PM, Ben Madin
<lists at remoteinformation.com.au>wrote:
> Nicholas,
> I can't answer 'What's the right way?', as I'm sure I don't have it yet,
> but I have found the biggest issue is in getting postgis to transfer, so I
> do it in steps:
> 1. always install postgis into it's own schema (either create the schema -
> gis - and set the search-path before \i postgis.sql command, or edit the
> postgis.sql file)
> 2. when dumping, ignore the gis schema = pg-dump -N gis database >
> database.dump
> 3. when recreating, create new database, import postgis (as in 1) then
> restore database.dump (psql newdatabase < database.dump)
> Or some variant of the above - and I'd love to know / be shown a better
> way!
> As a side benefit (If it helps,) I also use the gis schema for reasonably
> static GIS data - background maps etc. Then my backups don't include it, and
> are often much smaller for it, which helps going between machines.
> cheers
> Ben
> On 09/04/2010, at 21:20 , Nicholas Bower wrote:
> > I'm trying to create a new instance on a different platform of a
> postgis-enabled database, starting with just the schema definition. What's
> the right way? This doesn't work below - do I have to partition into
> separate schemas to have this work perhaps? Thanks, Nick
> > [Solaris Postgis 1.3.4] pg_dump -scFc database > schema.sql
> > [Windows Postgis 1.5.1] pgrestore -d database schema.sql
> > End result - lots of errors and missing any tables containing postgis
> objects. Note the hard coded c language function library paths below;
> > pg_restore: [archiver (db)] Error while PROCESSING TOC:
> > pg_restore: [archiver (db)] Error from TOC entry 6; 2615 18201 SCHEMA
> wastac wastacad
> > pg_restore: [archiver (db)] could not execute query: ERROR: schema
> "wastac" already exists
> > Command was:
> > CREATE SCHEMA wastac;
> > pg_restore: [archiver (db)] Error from TOC entry 1223; 2612 17398
> PROCEDURAL LANGUAGE plpgsql postgres
> > pg_restore: [archiver (db)] could not execute query: ERROR: language
> "plpgsql"
> > already exists
> > Command was: CREATE PROCEDURAL LANGUAGE plpgsql;
> > pg_restore: [archiver (db)] Error from TOC entry 1115; 0 0 SHELL TYPE
> box2d postgres
> > pg_restore: [archiver (db)] could not execute query: ERROR: type "box2d"
> already exists
> > Command was: CREATE TYPE box2d;
> > pg_restore: [archiver (db)] Error from TOC entry 216; 1255 17477 FUNCTION
> st_box2d_in(cstring) postgres
> > pg_restore: [archiver (db)] could not execute query: ERROR: permission
> denied for language c
> > Command was: CREATE FUNCTION st_box2d_in(cstring) RETURNS box2d
> > AS '/usr/local/postgis-1.3.4/lib/liblwgeom', 'BOX2DFLOAT4_in'
> > LAN...
> > pg_restore: [archiver (db)] could not execute query: ERROR: function
> public.st_box2d_in(cstring) does not exist
> > Command was: ALTER FUNCTION public.st_box2d_in(cstring) OWNER TO
> postgres;
> > pg_restore: [archiver (db)] Error from TOC entry 218; 1255 17479 FUNCTION
> st_box2d_out(box2d) postgres
> > Command was: CREATE FUNCTION st_box2d_out(box2d) RETURNS cstring
> > AS '/usr/local/postgis-1.3.4/lib/liblwgeom', 'BOX2DFLOAT4_out'
> > L...
> public.st_box2d_out(box2d) does not exist
> > Command was: ALTER FUNCTION public.st_box2d_out(box2d) OWNER TO
> postgres;
> > pg_restore: [archiver (db)] Error from TOC entry 1114; 1247 17475 TYPE
> box2d postgres
> > pg_restore: [archiver (db)] could not execute query: ERROR: relation
> "t_tile_geometry" does not exist
> > Command was: GRANT SELECT ON TABLE t_tile_geometry TO wastacportal;
> > Command was: GRANT SELECT,INSERT,DELETE,UPDATE ON TABLE
> t_tile_geometry TO wastac;
> > WARNING: errors ignored on restore: 1586
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100411/2416df62/attachment.html>
