[postgis-users] Conversion from undefined geometry to geography?
Nicholas Bower nick at petangent.net
Tue Apr 13 23:03:08 PDT 2010
Ok thanks - so this is really my solution by the looks;
UPDATE mytable SET new_geog_col = geography(ST_SetSRID(old_geom_col, 4326));
Be curious to see how it performs on a quarter billion rows - hopefully
should be fine with constraints/indexes dropped as usual.
On Wed, Apr 14, 2010 at 3:50 PM, Paragon Corporation <lr at pcorp.us> wrote:
> You mean ST_SetSRID :)
> R
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Tuesday, April 13, 2010 11:59 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Conversion from undefined geometry to
> geography?
> Just use geography(the_geom), it'll work fine. If you fine you have srid
> issues (I don't think you should) use
> geography(setsrid(the_geom,4326))
> P
> On Tue, Apr 13, 2010 at 8:47 PM, Nicholas Bower <nick at petangent.net>
> wrote:
> > We have some tables in which we've used Geometry to store polygon and
> > point lan/lon (srid = -1).  We embarked on this before PostGIS 1.5.x's
> > spherical Geography objects.
> > Now we intend to upgrade and migrate these to new Geography types (eg
> > new geography col, copy/convert, drop original geometry col).
> > Is there an existing function that provides a conversion from Geometry
> > to Geography that could be used in a simple table update?  This
> > doesn't give away too many clues what will happen when given a
> > geometry with srid = -1 for example:
> > http://postgis.refractions.net/docs/geography.html
> > TIA.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100414/7a3e0f5c/attachment.html>
