[postgis-users] PostGIS 1.5.1 causing postmaster crash on index creation
Nick Bower
nick at petangent.net
Thu Apr 15 14:28:07 PDT 2010
Yes geography - migrated data from a geometry column (as per
suggestion in other thread).
I'll work on getting a dump for you to reproduce over the w/e.
On 16/04/2010, at 12:32 AM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Nicholas,
> Could you confirm that the crash is building an index on a *geography*
> column, not a *geometry* column? Ie, the problem has not been
> introduced to old geometry code, it's something in the new geography
> code.
> After that I'm going to need the data that causes the error...
> Paul
> On Thu, Apr 15, 2010 at 5:51 AM, Nicholas Bower <nick at petangent.net>
> wrote:
>> Just upgraded to PostGIS 1.5.1 on a windows XP machine (from 1.3.4)
>> and when
>> creating an index on a geography column using this single statement;
>> CREATE INDEX t_swath_metadata_swath_bounding_key ON
>> wastac.t_swath_metadata
>> USING gist (swath_bounding);
> postgis-users mailing list
