[postgis-users] upgrading from 1.4 to 1.5.1
P Kishor
punk.kish at gmail.com
Mon Apr 19 11:21:13 PDT 2010
Per the docs at
<http://www.postgis.org/documentation/manual-1.5/ch02.html#upgrading>,
I "should find several postgis_upgrade*.sql files." But, it doesn't
say where I should find them. A little bit of poking around revealed
the following files to be inside the postgis directory
punkish at Lucknow ~/Projects/postgis-1.5.1$ll postgis
-rw-r--r-- 1 punkish punkish 173460 Apr 19 12:51 postgis_upgrade_13_to_15.sql
-rw-r--r-- 1 punkish punkish 173221 Apr 19 12:51 postgis_upgrade_14_to_15.sql
-rw-r--r-- 1 punkish punkish 170268 Apr 19 12:51 postgis_upgrade_15_minor.sql
So, I suggest the documentation be corrected to "you should find
several postgis_upgrade*.sql files in the 'postgis' folder."
Then, I ran the following command, and got errors --
punkish at Lucknow ~/Projects/postgis-1.5.1$psql -f
postgis/postgis_upgrade_14_to_15.sql -d dbname
BEGIN
CREATE FUNCTION
postgis_major_version_check
Scripts versions checked for upgrade: ok
(1 row)
DROP FUNCTION
psql:postgis/postgis_upgrade_14_to_15.sql:49: ERROR: could not access
file "$libdir/postgis-1.5": No such file or directory
psql:postgis/postgis_upgrade_14_to_15.sql:53: ERROR: current
transaction is aborted, commands ignored until end of transaction
block
and so on.
Suggestions?
Puneet Kishor
