[postgis-users] How to setup a versioned datastore?
Dominik Wiedner DominikWiedner at web.de
Wed Aug 4 00:46:46 PDT 2010
I also downloaded the extension and managed to install it within the
target database. But when I attempt to enable the target-table, I get
the following error:
HINWEIS: CREATE TABLE erstellt implizit eine Sequenz
»uberschwemmungsgebiete_h
istory_history_id_seq« für die »serial«-Spalte
»uberschwemmungsgebiete_hist
ory.history_id«
KONTEXT: SQL-Anweisung »CREATE TABLE
public.Uberschwemmungsgebiete_history(history_id serial not
null,date_added timestamp not null default now(),date_deleted
timestamp default null,last_operation varchar(30) not null,active_user
varchar(90) not null default CURRENT_USER,current_version text not
null,like public.Uberschwemmungsgebiete,CONSTRAINT
Uberschwemmungsgebiete_history_pk primary key(history_id));«
PL/pgSQL function "postgis_enable_history" line 66 at EXECUTE-Anweisung
FEHLER: Relation »public.uberschwemmungsgebiete« existiert nicht <<<<
This is the error I mean, since the table has the schema "public".
ZEILE 1: ...t CURRENT_USER,current_version text not null,like public.Ube...
ANFRAGE: CREATE TABLE public.Uberschwemmungsgebiete_history(history_id
serial not null,date_added timestamp not null default now(),date_deleted
KONTEXT: PL/pgSQL function "postgis_enable_history" line 66 at
EXECUTE-Anweisung
Any hints?
Regards,
Dominik
