[postgis-users] Backup and Restore of a PostGis database
Fred Lehodey
lehodey at gmail.com
Wed Aug 4 04:35:49 PDT 2010
Hi Luís,
you may need to do first a "backup globals" of the entire database cluster
A. (to import users, etc..)
A good practice (I think) is to avoid public schema for data...
Then, for option B, you can backup only data schemas (and use postgis
function to populate geometry_columns at the end)
Fred.
2010/8/4 Luís de Sousa <luis.a.de.sousa at gmail.com>
> Dear all,
> I'm having a hard time porting a postgis database to another server
> (let's call server A the one where the original database resides and
> server B the one where I need to replicate the database). I'm trying
> it in two different ways:
> 1. Creating a fresh empty database at server B and then restoring.
> With this process PostGres complains of not having permissions to
> create basic types.
> 2. Creating a fresh database from the PostGis template. This way
> PostGres complains of objects that already exist.
> At the root of this is the fact that when dumping a PostGis database,
> all PostGis objects are created, functions, types, etc. Is there a way
> of making a dump excluding the creation of PostGis objects?
> Thank you,
> Luís
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100804/56d8ca85/attachment.html>
