[postgis-users] st_transform, irreversible?
Paul Ramsey
pramsey at opengeo.org
Wed Aug 11 13:39:48 PDT 2010
Removing the EPSG lookup from the equation changes nothing:
echo "59 21" | proj +proj=tmerc +lat_0=0 +lon_0=15.80827777777778 +k=1
+x_0=1500000 +y_0=0 +ellps=bessel +units=m +no_defs | invproj
+proj=tmerc +lat_0=0 +lon_0=15.80827777777778 +k=1 +x_0=1500000 +y_0=0
58d49'47.733"E 21d2'54.745"N
P.
On Wed, Aug 11, 2010 at 1:35 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Seems to be an underlying problem with proj4:
> echo "59 21" | proj "+init=epsg:3021" | invproj "+init=epsg:3021"
> And that's without doing the datum shift part.
> P
> On Wed, Aug 11, 2010 at 1:10 PM, Erik Rehn <erik at slagkryssaren.com> wrote:
>> Hello Postgis Users!
>> This is my first post on this list so I will start by asking
>> a simple (and probably stupid) question. :)
>> While using ST_AsKml() to produce an overlay for Google Earth I
>> noticed that all my geometries where shifted slightly south-east.
>> I figured this had something to do with the transformation between
>> the projection that my geometries are stored in (SRID 3021) and WGS84 (4326)
>> that is outputted by ST_AsKml()
>> Just to test I ran this:
>> SELECT ST_AsText(
>> ST_Transform(
>> ST_Transform(
>> ST_GeomFromText('POINT(59 18)',4326),
>> 3021),
>> 4326));
>> I input a point in WGS84 (59,18), transforms it to 3021 and then back to
>> WGS84. The result I get is:
>> POINT(58.8672757036296 18.0394763349359)
>> Can anyone explain this? Am I missing something regarding ST_Transform()?
>> Im running Postgis 1.5 on Windows.
>> Thank you for any help!
>> /Erik
>> Erik Rehn
>> Slagkryssaren
>> www.slagkryssaren.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
