[postgis-users] st_transform, irreversible?
Ricardo Bayley
ricardo.bayley at gmail.com
Thu Aug 12 08:05:03 PDT 2010
very nice explanation Mike
On Thu, Aug 12, 2010 at 11:39 AM, Mike Toews <mwtoews at gmail.com> wrote:
> Hi,
> Your coordinates may be flipped. Was it 59N 18E? If so, use x,y
> notation: 'POINT(18 59)', which results in 'POINT(18.0000000000006
> 58.9999999999905)', which is close enough.
> Also keep in mind that you are outside the projection bounds:
> http://spatialreference.org/ref/epsg/3021/ (just a bit too far east).
> Whenever you are outside the projection bounds, the likelihood of
> storage precision errors increase. To understand why this is, you can
> think of taking the tangent of a two angles that are nearly a
> right-angle (89.9991 and 89.9992) which have very different results
> due to nature of the geometry.
> -Mike
> On 11 August 2010 13:10, Erik Rehn <erik at slagkryssaren.com> wrote:
> > Hello Postgis Users!
> > This is my first post on this list so I will start by asking
> > a simple (and probably stupid) question. :)
> > While using ST_AsKml() to produce an overlay for Google Earth I
> > noticed that all my geometries where shifted slightly south-east.
> > I figured this had something to do with the transformation between
> > the projection that my geometries are stored in (SRID 3021) and WGS84
> (4326)
> > that is outputted by ST_AsKml()
> > Just to test I ran this:
> > SELECT ST_AsText(
> > ST_Transform(
> > ST_Transform(
> > ST_GeomFromText('POINT(59 18)',4326),
> > 3021),
> > 4326));
> > I input a point in WGS84 (59,18), transforms it to 3021 and then back to
> > WGS84. The result I get is:
> > POINT(58.8672757036296 18.0394763349359)
> > Can anyone explain this? Am I missing something regarding ST_Transform()?
> > Im running Postgis 1.5 on Windows.
> > Thank you for any help!
> > /Erik
> > Erik Rehn
> > Slagkryssaren
> > www.slagkryssaren.com
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100812/db589486/attachment.html>
