[postgis-users] Convert already loaded table into a spatial table
Appel, Tony
tony.appel at navteq.com
Fri Aug 13 05:01:49 PDT 2010
Thanks for all the answers. This is what I used.
UPDATE point SET geom = setsrid(makepoint(longitude, latitude, height), 4326);
Tony
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of postgis-users-request at postgis.refractions.net
Sent: Thursday, August 12, 2010 2:00 PM
To: postgis-users at postgis.refractions.net
Subject: postgis-users Digest, Vol 100, Issue 10
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://postgis.refractions.net/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-users-owner at postgis.refractions.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of postgis-users digest..."
Today's Topics:
1. st_transform, irreversible? (Erik Rehn)
2. Re: st_transform, irreversible? (Paul Ramsey)
3. Re: st_transform, irreversible? (Paul Ramsey)
4. making polygons from center + vertex (Arnaud Sahuguet)
5. Re: making polygons from center + vertex (Francis Markham)
6. Re: making polygons from center + vertex (Arnaud Sahuguet)
7. Re: st_transform, irreversible? (Barend K?bben)
8. Re: st_transform, irreversible? (Mike Toews)
9. Re: st_transform, irreversible? (Ricardo Bayley)
10. Turn restrictions and directions of road on postgis pgrouting
table. (FRANK RADA)
11. Detecting wrong geometries (Andrea Peri)
12. Re: Detecting wrong geometries (Nicolas Ribot)
13. Re: Detecting wrong geometries (Andrea Peri)
14. Convert already loaded table into a spatial table (points)
(Appel, Tony)
15. Detecting wrong geometries (Andrea Peri)
16. Re: Convert already loaded table into a spatial table
(points) (Fabio Renzo Panettieri)
17. Re: Convert already loaded table into a spatial table
18. Convert already loaded table into a spatial table (points)
(Andrea Peri)
19. Re: Convert already loaded table into a spatial table
(points) (Fred Lehodey)
20. Re: Convert already loaded table into a spatial table
(points) (Paul Ramsey)
Message: 1
Date: Wed, 11 Aug 2010 22:10:14 +0200
Subject: [postgis-users] st_transform, irreversible?
Message-ID: <4C6303A6.3010108 at slagkryssaren.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hello Postgis Users!
This is my first post on this list so I will start by asking
a simple (and probably stupid) question. :)
While using ST_AsKml() to produce an overlay for Google Earth I
noticed that all my geometries where shifted slightly south-east.
I figured this had something to do with the transformation between
the projection that my geometries are stored in (SRID 3021) and WGS84
(4326) that is outputted by ST_AsKml()
Just to test I ran this:
SELECT ST_AsText(
ST_Transform(
ST_Transform(
ST_GeomFromText('POINT(59 18)',4326),
3021),
4326));
I input a point in WGS84 (59,18), transforms it to 3021 and then back to
WGS84. The result I get is:
POINT(58.8672757036296 18.0394763349359)
Can anyone explain this? Am I missing something regarding ST_Transform()?
Im running Postgis 1.5 on Windows.
Thank you for any help!
/Erik
Erik Rehn
Slagkryssaren
erik at slagkryssaren.com
www.slagkryssaren.com
Message: 2
Date: Wed, 11 Aug 2010 13:35:46 -0700
Subject: Re: [postgis-users] st_transform, irreversible?
To: erik at slagkryssaren.com, PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
Cc: metacrs at lists.osgeo.org
Message-ID:
<AANLkTin4TvWR=ccBxSHM4WW3o1nt23B2nf49sJtAUGPg at mail.gmail.com>
Seems to be an underlying problem with proj4:
echo "59 21" | proj "+init=epsg:3021" | invproj "+init=epsg:3021"
58d49'47.733"E 21d2'54.745"N
And that's without doing the datum shift part.
P
On Wed, Aug 11, 2010 at 1:10 PM, Erik Rehn <erik at slagkryssaren.com> wrote:
> the projection that my geometries are stored in (SRID 3021) and WGS84 (4326)
> SELECT ST_AsText(
> ? ?ST_Transform(
> ? ? ? ?ST_Transform(
> ? ? ? ? ? ?ST_GeomFromText('POINT(59 18)',4326),
> ? ? ? ?3021),
> ? ?4326));
> /Erik
> Erik Rehn
> Slagkryssaren
Message: 3
Date: Wed, 11 Aug 2010 13:39:48 -0700
Message-ID:
<AANLkTim_JWEi9xTE6tR90kLqcU3pB7wEx6h2NsT9WyKn at mail.gmail.com>
Removing the EPSG lookup from the equation changes nothing:
echo "59 21" | proj +proj=tmerc +lat_0=0 +lon_0=15.80827777777778 +k=1
+x_0=1500000 +y_0=0 +ellps=bessel +units=m +no_defs | invproj
+proj=tmerc +lat_0=0 +lon_0=15.80827777777778 +k=1 +x_0=1500000 +y_0=0
P.
> 58d49'47.733"E ?21d2'54.745"N
> P
>> SELECT ST_AsText(
>> ? ?ST_Transform(
>> ? ? ? ?3021),
>> ? ?4326));
>> /Erik
>> Erik Rehn
>> Slagkryssaren
Message: 4
Date: Wed, 11 Aug 2010 21:36:10 -0400
From: Arnaud Sahuguet <arnaud.sahuguet at gmail.com>
Subject: [postgis-users] making polygons from center + vertex
Message-ID:
<AANLkTi=CO=7fxTqbFcMgXwpkcfvKByQ3uk93q18_=PvB at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
I found this really neat Google Maps example where you can draw polygons
using 2 points: the center and one vertex.
See http://www.barnabu.co.uk/geapi/polyplot/
Is there a POST GIS function to create the corresponding polygon?
regards,
Arnaud Sahuguet
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100811/04de817c/attachment-0001.html>
Message: 5
Date: Thu, 12 Aug 2010 12:04:03 +1000
Subject: Re: [postgis-users] making polygons from center + vertex
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID:
<AANLkTimRXnk-ySt8GcHa_Rc6ZuAZ0yy2agp_QCsDCbQp at mail.gmail.com>
Sure is, check out the ST_Buffer function
http://postgis.refractions.net/docs/ST_Buffer.html
ST_Buffer(geometry g1, float radius_of_buffer);
If you give it a point as g1, and the radius of the circle it will
calculate a pseduo-circular polygon for you. If you have two points
g1 and g2 you could use ST_Buffer(g1, ST_Distance(g1, g2));
-Francis
On 12 August 2010 11:36, Arnaud Sahuguet <arnaud.sahuguet at gmail.com> wrote:
> I found this really neat Google Maps example where you can draw polygons using 2 points: the center and one vertex.
> See?http://www.barnabu.co.uk/geapi/polyplot/
> regards,
> Arnaud Sahuguet
Message: 6
Date: Wed, 11 Aug 2010 22:30:10 -0400
Message-ID:
<AANLkTikc_DXC4u-oqBNgci-9Gv7V4Y8wMsPXU+Xo0hQ7 at mail.gmail.com>
thanks.
Arnaud
On Wed, Aug 11, 2010 at 10:04 PM, Francis Markham <fmarkham at gmail.com>wrote:
> -Francis
> > regards,
> > Arnaud Sahuguet
Arnaud Sahuguet
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100811/6fd6f6ec/attachment-0001.html>
Message: 7
Date: Thu, 12 Aug 2010 16:24:17 +0200
Message-ID: <C889D0B1.141E0%kobben at itc.nl>
I think that is because many projections can indeed not be reversed, i.e.
the math is sometimes not straight formulas but iterative approximations and
you'll get rounding errors, etcetera...
Barend K?bben
Senior Lecturer
ITC ? University of Twente, Faculty of Geo-Information Science and
Earth Observation
PO Box 217, 7500AA Enschede, The Netherlands
+31 (0)53 4874253
> P.
>> P
>>> SELECT ST_AsText(
>>> ? ?ST_Transform(
>>> ? ? ? ?3021),
>>> ? ?4326));
>>> /Erik
>>> Erik Rehn
>>> Slagkryssaren
Faculty of Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
Message: 8
Date: Thu, 12 Aug 2010 07:39:36 -0700
Message-ID:
<AANLkTikb76+yzZEMfP7gqc5W55qEGEpyttuhUk5hcMPG at mail.gmail.com>
Your coordinates may be flipped. Was it 59N 18E? If so, use x,y
notation: 'POINT(18 59)', which results in 'POINT(18.0000000000006
58.9999999999905)', which is close enough.
Also keep in mind that you are outside the projection bounds:
http://spatialreference.org/ref/epsg/3021/ (just a bit too far east).
Whenever you are outside the projection bounds, the likelihood of
storage precision errors increase. To understand why this is, you can
think of taking the tangent of a two angles that are nearly a
right-angle (89.9991 and 89.9992) which have very different results
due to nature of the geometry.
-Mike
> SELECT ST_AsText(
> ? ?ST_Transform(
> ? ? ? ?3021),
> ? ?4326));
> /Erik
> Erik Rehn
> Slagkryssaren
Message: 9
Date: Thu, 12 Aug 2010 12:05:03 -0300
Message-ID:
<AANLkTimv2j2m1N1f7y3nr3GKvQUxzB1X-L0oByKFznuM at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
very nice explanation Mike
On Thu, Aug 12, 2010 at 11:39 AM, Mike Toews <mwtoews at gmail.com> wrote:
> Hi,
> -Mike
> (4326)
> > SELECT ST_AsText(
> > ST_Transform(
> > ST_Transform(
> > 3021),
> > 4326));
> > /Erik
> > Erik Rehn
> > Slagkryssaren
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/db589486/attachment-0001.html>
Message: 10
Date: Thu, 12 Aug 2010 10:19:43 -0500
Subject: [postgis-users] Turn restrictions and directions of road on
postgis pgrouting table.
Message-ID:
<AANLkTi=AmPB2SQ4diHRHCCf6neXno33g3JEFf5+hgk10 at mail.gmail.com>
---------- Forwarded message ----------
Date: 2010/8/6
Subject: Turn restrictions and directions of road on postgis pgrouting table.
HI.
firts that all , excuse my english, it's very bad. i tell to you that
I'm doing a routing program, i build the graph table with the
pgrouting functions, this is: the tmp_vertices table and the ways with
edges table.
but i need model the turn restrictions and ?directions of road. any idea?
appreciate your help.
Message: 11
Date: Thu, 12 Aug 2010 18:51:17 +0200
Subject: [postgis-users] Detecting wrong geometries
Message-ID:
<AANLkTi=AfO6OL2MDpCoSDg3tQ4aM2BmR33KDo6Wkik9B at mail.gmail.com>
I needed to test a shapefile to find eventually wrong geometries.
My first idea was to use postgis to do a
select *from table_from_shapefile where ST_IsValid(geom)=false;
So I load the shapefile with shp2pgsql in postgis (1.5.1)
and do this query.
The results was 1 only geometry wrong.
After some days I repeat the same test with Grass.
Grass with my big surprise report me more geometry wrong.
Infact in the shapefile was detected many geometries with wrong orientation.
Now my question is why this was not detected from postgis ?
I don't know why,
but my idea is that perhaps shp2pgsql, when find a geometry wrong oriented
correct it automatically .
Is this correct ?
Thx,
Andrea Peri.
Andrea Peri
qwerty ?????
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/d178cef5/attachment-0001.html>
Message: 12
Date: Thu, 12 Aug 2010 19:14:48 +0200
Subject: Re: [postgis-users] Detecting wrong geometries
Message-ID:
<AANLkTimr6dFvzuknEBjQx=+xpZYp4MMu-OH_FNNoG1Rx at mail.gmail.com>
On 12 August 2010 18:51, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> and do this query.
> I don't know why,
> Is this correct ?
> Thx,
Polygon orientation is not important with respect to OGC
specifications and does not define an invalid polygon.
That's why st_isvalid() returns true in Postgis.
You can, however, force polygon orientation using the st_forceRHR()
function (http://postgis.refractions.net/docs/ST_ForceRHR.html).
Nicolas
PS. the Jump software (http://www.vividsolutions.com/jump/) has a nice
validation tool in which you can enable this constraint when
validating a layer.
With the postgis plugin, you can perform this validation directly on a
postgis table.
It graphically spots invalid geometries and also generate a new layer,
with attributes telling the reason of invalidity.
Message: 13
Date: Thu, 12 Aug 2010 19:41:27 +0200
To: Brent Wood <pcreso at yahoo.com>
Cc: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID:
<AANLkTikd86xECfdpsvHScQyzTW9ua8beb0_qTcMG3RNS at mail.gmail.com>
2010/8/12 Brent Wood <pcreso at yahoo.com>
> Hi Andrea,
> What do you mean by a "wrong" geometry? One that failed to load?
> Did you use the postgis function ST_isvalid() function to test?
> Brent Wood
Yes,
After load in postgres
I try a
select count(*) from table where ST_IsValid(geom)=false;
and have a result of 1 only invalid geometry.
Andrea Peri
qwerty ?????
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/6d526223/attachment-0001.html>
Message: 14
Date: Thu, 12 Aug 2010 12:53:54 -0500
Subject: [postgis-users] Convert already loaded table into a spatial
table (points)
To: "postgis-users at postgis.refractions.net"
Message-ID:
<64E02D5C219FD949B70C6D871B37406B0CB51C4C67 at f-exch-mb1.ad.navteq.com>
Content-Type: text/plain; charset="us-ascii"
I have already loaded a table that contains X, Y and Z values. AT the time of loading it was thought we did not need a spatial component to this table.
Now we realize that we do have a need but do not want to reload the 190 million records again and create the point features on load.
Is it possible to create the point geometry in the existing table....if so, how?
Thanks in advance.
Tony Appel
The information contained in this communication may be CONFIDENTIAL and is intended only for the use of the recipient(s) named above. If you are not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication, or any of its contents, is strictly prohibited. If you have received this communication in error, please notify the sender and delete/destroy the original message and any copy of it from your computer or paper files.
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/c286b87f/attachment-0001.html>
Message: 15
Date: Thu, 12 Aug 2010 20:02:07 +0200
Message-ID:
<AANLkTin4ne0iM=fUoG_CsBx0HYwQON5PLdw+DJn3zjPC at mail.gmail.com>
>Hi,
>Nicolas
Thx for clear response.
But I like to understand better why this strategy.
When load from a shapefile with shp2pgsql the source of data is a shapefile
with follow the ESRI specifics, and it is not an OGC source.
So the meaning of the geometry in the shapefile must following the specific
of the esri document.
This mean that a geometry counter-clockwise is a hole, or is a mistake.
If it is a hole then if the goal is to load exactly what there is in the
shapefile is needed to load the hole :).
If it is a mistake then is needed report the mistake and not load that
geometry.
I prefer the first choice of course, but I'm not sure to understand why load
something else that is changed from the original is better.
Andrea Peri
qwerty ?????
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/cfd78919/attachment-0001.html>
Message: 16
Date: Thu, 12 Aug 2010 15:03:46 -0300
From: Fabio Renzo Panettieri <fpanettieri at xoomcode.com>
Subject: Re: [postgis-users] Convert already loaded table into a
Message-ID: <1281636226.5699.3.camel at radon>
Content-Type: text/plain; charset="UTF-8"
> this table.
> Is it possible to create the point geometry in the existing table?.if
> so, how?
You can always add a new geometry column to your existing table.
SELECT AddGeometryColumn
('public','my_table','the_geom',4326,'POINT',2);
http://postgis.refractions.net/docs/AddGeometryColumn.html
And after that you create the geometries, assuming you have points stored:
UPDATE my_table SET the_geom = ST_MakePoint(x, y, z);
http://postgis.refractions.net/docs/ST_MakePoint.html
Fabio R. Panettieri
Software Architect
http://www.xoomcode.com
Message: 17
Date: Thu, 12 Aug 2010 15:06:54 -0300
To: fpanettieri at xoomcode.com, PostGIS Users Discussion
Message-ID: <1281636414.5699.5.camel at radon>
Ups, my mistake. This should be
('public','my_table','the_geom',4326,'POINT',3);
Fabio R. Panettieri
Software Architect
Message: 18
Date: Thu, 12 Aug 2010 20:09:32 +0200
table (points)
Message-ID:
<AANLkTimeZ6Q+nUotaPi873SERSLc+HLSaxuP06yH1rQm at mail.gmail.com>
>Thanks in advance.
>Tony Appel
Assume the X,Y,Z are in three fields in a "tablename" table.
SELECT AddGeometryColumn( 'public','tablename','geom', <epsg>, 'POINT', 3 );
update public.tablename set geom = ST_MakePoint(X::double,Y::double,Z::double);
epsg is a integer value of your SRS (epsg code)
Regards,
Andrea Peri
qwerty ?????
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/796fe128/attachment-0001.html>
Message: 19
Date: Thu, 12 Aug 2010 19:14:40 +0100
Message-ID:
<AANLkTim-K6bU3ZebbBxtS+1DAccNe67ksSJC1f0KRj9q at mail.gmail.com>
ST_MakePoint return point with unknow geometry.
You need to use something like:
ST_SetSRID(ST_MakePoint(x,y,z),<your_srid>)
Fred
> >Thanks in advance.
> >Tony Appel
> Regards,
> Andrea Peri
> qwerty ?????
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100812/05c8e824/attachment-0001.html>
Message: 20
Date: Thu, 12 Aug 2010 11:56:57 -0700
Message-ID:
<AANLkTi=QaybGCg7srVYaRA7042PQ4D+kn6_ZMkubbMsv at mail.gmail.com>
Content-Type: text/plain; charset=windows-1252
Because of transaction handling, updating every row in a database is
the equivalent of a full load. It might actually take longer than the
initial load.
I'd suggest something like
create newtable as select st_makepoint(x,y) as point, a1, a2, a2...
from oldtable
drop oldtable
alter newtable rename to oldtable
P.
On Thu, Aug 12, 2010 at 11:03 AM, Fabio Renzo Panettieri
>> this table.
>> so, how?
> Fabio R. Panettieri
> Software Architect
End of postgis-users Digest, Vol 100, Issue 10
