[postgis-users] Shape file importer. broken multipolygon
    Nicolas Gillet - MARKET-IP
    nicolas.gillet at market-ip.com
    Tue Aug 17 04:20:28 PDT 2010
Hello List,
I used the PGAdmin III plug-in to import shape files into my database but
I'm facing a problem.
The shape file I am importing contains multi-polygon but the resulting table
after import contains only single polygon and some polygons are then lost.
Only one polygon is imported for every multi-polygon in the file.
If I use the shp2pqsql command line tool (instead of GUI), I have the right
result. My multi-polygons are as they're supposed to be.
So I think that the import plug-in is somehow configured to use something
like the "-S" forced switch of the shp2pqsql tool but I don't find such
option in the plug-in's options.
I use a PosgreSql 8.4, Postgis 1.5 with PgAdmin III.
The import plugin version is : shp2pgsql-gui $Revision: 5094 $.
Any idea of what's wrong ?
Thanks for any input.
Nicolas
Gillet
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100817/c86ed134/attachment.html>
