[postgis-users] Shape file importer. broken multipolygon
Nicolas Gillet - MARKET-IP
nicolas.gillet at market-ip.com
Wed Aug 18 06:48:41 PDT 2010
Hello Mark,
I made a mistake in my previous mail.
The postgis version I used was 1.4.1. I was confused with the postigis I
installed a month ago in another computer.
I downloaded the windows package one click installer and then use the stack
builder to install the postgis extension.
As you said that it was fixed, I upgraded my server and extensions with the
new version of the windows installer.
Now everything works fine and GUI importer behaves perfectly.
Thank you , you put me on the right way.
Best regards.
Nicolas.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, August 18, 2010 11:36 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Shape file importer. broken multipolygon
Hi Nicolas,
It looks as if this bug has already been fixed in r5195, and hence
should be included from PostGIS 1.5.0 onwards. Where did you get your
PostGIS binaries from?
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Cave-Ayland
Sent: Wednesday, August 18, 2010 11:35 AM
Nicolas Gillet - MARKET-IP wrote:
> Hello List,
> I used the PGAdmin III plug-in to import shape files into my database
> but I'm facing a problem.
> The shape file I am importing contains multi-polygon but the resulting
> table after import contains only single polygon and some polygons are
> then lost.
> Only one polygon is imported for every multi-polygon in the file.
> If I use the shp2pqsql command line tool (instead of GUI), I have the
> right result. My multi-polygons are as they're supposed to be.
> So I think that the import plug-in is somehow configured to use
> something like the "-S" forced switch of the shp2pqsql tool but I don't
> find such option in the plug-in's options.
> I use a PosgreSql 8.4, Postgis 1.5 with PgAdmin III.
> The import plugin version is : shp2pgsql-gui $Revision: 5094 $.
> Any idea of what's wrong ?
> Thanks for any input.
> Nicolas
