[postgis-users] QGIS requires
Aman Verma
aman.verma at mcgill.ca
Wed Aug 18 11:05:59 PDT 2010
Yes, there is a way to do this.
First, you have to create a 'sequence'. But you only have to do this once. It won't really matter if several different tables are using the same sequence in your situation.
create sequence sq; -- You only have to do this once. You could also make a temporary sequence. create temporary...
CREATE VIEW my_view AS (SELECT
nextval('sq'), -- this is the function to access the next number from your sequence.
St_Union(wkb_geometry) FROM my_subregions GROUP BY region_id);
aman
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of William Furnass
Sent: August 18, 2010 1:52 PM
To: PostGIS Users Discussion
Subject: [postgis-users] QGIS requires
QGIS requires that all PostGIS tables/views have a numeric primary
key. As a result I have had to create many temporary tables solely
for the purpose of viewing the results of queries when ideally I would
have liked to create views from the majority of my queries. Does
anyone know if I can create on-the-fly a serial numeric column in
queries/views to save me having to create so many temporary tables?
It'd be grand if something like the following were possible:
CREATE VIEW my_view AS (SELECT numeric_id_generator(),
Cheers,
Will
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
