[postgis-users] using && operator
Jan Saalbach
fire at dubmosphere.de
Fri Aug 20 07:01:39 PDT 2010
Hi List,
how do I check if two 3d-point sets overlap? I see the && operator
should be able to compare the bounding boxes, but how do I do it? I
can not get the && or ST_Intersects function to work. Here is what I
am trying to do:
SELECT ST_Collect(pkt) FROM pktbsp && ST_Collect(pkt) FROM pktbsp2;
pkt are GeometryColumns filled with 3dpoints. pktbsp and pktbsp2 are
the respective tables.
How can I check this?
Reagrds,
Jan
